04-03-2011, 07:54 AM | #1 |
Rock Stacker Join Date: Oct 2010 Location: glendale
| M2 dig helpppp
Anyone ever have the issue of. One motor does forward and reverse and motor two just does forward ....?. ...... I'm opposing my dAmn mind here |
04-03-2011, 11:00 AM | #2 |
Never seen this problem with my M2. I check and make sure you don't have a stuck brush on the 2nd motor that is preventing it from going in reverse. • Try swapping the leads to the motors, having the front leads wired up to the back motor and vise-versa. - If the problem moves to the other motor, and the motor that had the problem operates properly, you have something wrong with the M2. - If the problem does not move, and the motor that had the problem still has it, you have something wrong with that motor... Let us know what you find out... |
04-03-2011, 11:23 AM | #3 |
Rock Stacker Join Date: Mar 2011 Location: apple valley
It's going to be something in your radio settings. My buddys dad just got this system and a m11 radio and he was having the same issue. then he just realized it was a trim setting in the radio.
04-03-2011, 12:17 PM | #4 |
I've. Tried it all. Both motors do the same thing tried resetting the radio and due the one step setup still does the same also just got the esc back from Novak the first one went up in smoke .. I'm thinking I should have done dual fxr's
04-03-2011, 12:31 PM | #5 |
i also think he had to reverse the motor wires on the rear motor. but he had the same issues. it took him literally a week to figure it out. and it wasnt resetting all the radio settings. if your haveing trouble tuneing one esc id think tuneing dual fxr's is gonna be a test as well.
04-03-2011, 06:13 PM | #6 |
Well. Final verdict today was the this esc is faulty also put the esc in another xr with The same radio. And. How amazing still doesn't. Work soo. My final sugestion is don't buy one of these pieces of garbage |
