04-03-2011, 02:49 PM | #1 |
Quarry Creeper Join Date: Dec 2010 Location: vegas
| Ok... Several ?'s here need advise pls.
Will try to make/keep this short and sweet. Specs: Clod axles/Novak 45T (2)/cc bec @7.4/outcry dual motor esc (2)/4PL Issues: when I use the "dig" the motors do not "lockup" 100%. A) is this normal/ B) can drag brk be adjusted on these outcry thru 4PL? I am not 100% sure on prog. on 4PL. I fried a serv.- cirrus- got VERY HOT. I hooked up my 645mg and it is getting hot. Normal? 1) Does anyone know if I can adjust drag brk on outcry? IF I am doing it right-through radio- doesn't seem to work. Also I put Team Trinity #4389s Red Med. Heavy Motor Springs in rear motor. Would say helped a "lil" w/dig. 2) Can I put Lucas Oil Red & Tacky in servo... will this help "cool" motor or do I use dielec. grease? Is it normal for 645mg to get warm/hot? @ 7.4 thru cc bec? 3) I have searched ALOT and only seem to find Novak, Tekin, and some other no name/cheap brands esc. Yes I know Novak/Tekin aren't no name/cheap brands. I have read alot of ppl are having "problems" w/Novak esc.'s. What would be a good choice for a esc w/adjustable drag brk. that can be reliable? Been to Castles web but cannot find info for anything for. Any and all thoughts sugg. are welcome. Thnx in advance! Sabo Last edited by sabohead; 04-04-2011 at 01:12 PM. |
04-03-2011, 04:38 PM | #2 |
Most ESC's, other than the Novak M2, require you to either: 1-Run 2 ESC's (4PL handles this nicely) 2-A "dig" of some sort for a single ESC (either an electronic dig like a Punk Dig, Hayek (SP), or similar....or....a servo dig) A 3ch radio can handle a dig easily. Best bet is 2 ESC's with the right RX since you can also do proportional, a 3ch RX at least gets you a dig. I'm running a 2.2 Bully with a single ESC (CC MM) & a servo dig on a 3PM-x. The "brake" is adjustable. |
04-03-2011, 04:44 PM | #3 | |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
Answers in green champ Quote:
04-03-2011, 07:16 PM | #4 |
Yes I wanna go to BETTER ESC's but just not sure which one's.
04-03-2011, 09:29 PM | #5 |
Ok. Best choice for compactness and adjustability for dual ESC's would be either Tekin FXR's or Mamba Micro Pros... If you stick with a single ESC there's a bucketload out there. Homles BRXL would be the pick of the bunch though. |
04-03-2011, 10:58 PM | #6 |
Thnx but I will stick w/2 esc's. Thats wht I was wanting info on, on which esc would be good. Thnx wideload for info! |
04-04-2011, 02:33 AM | #7 |
| CORRECTION: info for good single esc. My bad
04-04-2011, 09:03 AM | #8 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
The divide the motors in half thing is not a good way to know if an ESC can handle the current. I would always contact them and ask. A good hand wound 20t will produce around 150 watts no problem. A good 10t will produce under 300 watts......a 10t limit ESC would get blown up by two 20t motors. Just an example.... Turns don't always correlate down in wattage......and current handing is the limit on an ESC (that have a limit). Later EddieO |
