Thread: DX3E and Sidewinder V2 Arming Problem
Old 04-06-2011, 10:03 AM   #1
Default DX3E and Sidewinder V2 Arming Problem
I can't get my DX3E to recalibrate or arm my Sidewinder V2. I can't seem to get my DX3E to a neutral with the trim. The light on the SWV2 is either flashing green or red. If I slightly pull the trigger it will go to the neutral and arm, but then it is not calibrated correctly. If I try holding the throttle down and then turn on power it does not go into recalibrate mode. This is driving me crazy. Is my DX3E messed up or am I missing something minor that will make me feel stupid?
Skeeno is offline   Reply With Quote
Old 04-06-2011, 10:56 AM   #2
Try re binding your reciever and see if that work set all your end points on your controler to neutral i had to do the same thing with mine cause the fail safe was causing the problem
9700trevor is offline   Reply With Quote
Old 04-06-2011, 02:24 PM   #3
I you have a castle link you can set the dead band wider to see if it will help.
GB's 05 is offline   Reply With Quote
Old 04-08-2011, 04:53 PM   #4
Still no luck. Im gonna take it down to my LHS and see what they can do with it.
