04-06-2011, 04:47 PM | #1 |
Rock Stacker Join Date: Jan 2010 Location: Bend
| scale winch that picks up more than 4 lbs???
It seems that the popular winches being used are not rated to pull very much weight. 3R racing pulls 2.2 lbs http://os.3racing.hk/products.php?products_key=3686 RCFWD bulldog pulls 4.4 lbs http://www.rpphobby.com/product_p/rc4z-e0015.htm How about this off road winch line made from 1:1 line? Couldn't find a load rating http://www.rpphobby.com/product_p/scav-sd00001.htm any other winches that I should consider? Some say either will pick their rig off the ground but have read threads that both will burn the motors up if they pull more than their rated capacity. Who's got one I should try that will pick up a 10lb scaler |
04-06-2011, 05:37 PM | #2 |
Pebble Pounder Join Date: Aug 2008 Location: Edmonds, WA
i think most people just use those winches for looks. everyone i know uses a modified servo for the winch.
04-06-2011, 06:23 PM | #3 |
Debunking old stereotypes Join Date: Feb 2006 Location: 1st and Amistad
04-06-2011, 06:26 PM | #4 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
Get yourself a Hitec 5645MG, a Heyok drift hack, one of my warpig winch spools, and my winch line, fairlead, and hook when its available this weekend.
04-06-2011, 06:35 PM | #5 |
Pebble Pounder Join Date: Nov 2010 Location: Texas
Anyone have any pics or diagrams on how to biuld a servo winch and how it is mounted on the scx10 chasis?
04-06-2011, 08:20 PM | #6 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
| Does this servo really work that well? I know alot of people use them, but i was surprised when i saw it was only 40 oz more then a 645. I ended up getting a savox @277 oz and alil faster transit time for the same money.
04-06-2011, 08:31 PM | #7 |
Rock Stacker Join Date: Jan 2008 Location: Tehachapi
OK, its looking good for the warpig, however, I keep hearing about the "servo" winches. How do you get a servo to rotate like a motor? I thought they all just go 90 deg except for model sailboat winches that usually only turn 5 or 6 revolutions? Thanks, in advance, Ron
04-06-2011, 08:50 PM | #8 |
Quarry Creeper Join Date: Aug 2004 Location: Southwestern PA
The easiest way is to replace the circut board in the servo with the drift-free controller from Heyok on here and remove the pin or step on the main output gear of the servo to allow it to rotate 360 degrees. Then all you have to do is figure out how to put a spool or drum on the output to wind the cable on... Check out Team3six's new servo spools, they look beefy and shiny... |
04-06-2011, 10:01 PM | #9 |
04-06-2011, 10:25 PM | #10 |
I just did this griz. Maybe as a Pasty will help. http://www.rccrawler.com/forum/showt...12#post3030312 |
04-07-2011, 09:42 AM | #11 | |
Nobody reads stickies though. | |
04-07-2011, 11:21 AM | #12 | |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
