04-07-2011, 09:39 AM | #1 |
Newbie Join Date: Mar 2011 Location: UK
| LiPo
Hi guys, i finally got my miniqlo and i love it. However, i dont know what charger to get. These are the batteries that were given : http://www.rcmart.com/catalog/rc-bat...m-p-30964.html Can you please let me know ASAP because i want to charge it up and get it out..thanks |
04-07-2011, 09:43 AM | #2 |
Oh yea, i forgot to ask you guys to recommend a charger with the same connector as well. Im not sure what connector is used on the pack..thanks again
04-07-2011, 10:01 AM | #3 |
Those look like JST balance connectors, I think the Hyperion balance connectors are larger. You can use any charger that charges 2s lipo. Get one with a built in balancer or buy a separate balance board. Maxamps make's all combination of adapters if you get the wrong connectors. Do you have a LHS? Just take the batteries there and ask them for a charger that fits. |
04-07-2011, 10:07 AM | #4 |
I dont think there is an LHS where i am (UK)..FML. What charger would you recommend?
04-07-2011, 08:45 PM | #5 |
I have bought this battery (http://www.rcmart.com/catalog/rc-bat...m-p-30964.html), how long do you guys reckon it will thake to fully charge using this charger (http://www.rcmart.com/catalog/rc-cha....html)..thanks |
04-07-2011, 08:50 PM | #6 |
Rock Crawler Join Date: Aug 2006 Location: Pinedale, WY
Probably about an hour, It usually takes me an hour to charge my 1000mah lipo packs @ 1amp. That charger you listed puts out .7amps and the batterys are 600mah, So around 50minutes to an hour |
04-07-2011, 08:57 PM | #7 |
owh i see, thanks mate. By the way, from that one hour of charging, how much run time do you get?
04-07-2011, 09:05 PM | #8 |
not sure on the runtime it depends on alot of factors but I would guess 20-40 minutes depending on your trigger finger |
04-07-2011, 09:11 PM | #9 |
RCC Addict Join Date: Apr 2008 Location: Sacramento
The batteries you are getting are more of a receiver pack, which is why it has the small red plug on it, also with the low 20C rating the battery is not designed to put out a lot of power, as long as you go slow and don't go full throttle a lot or for longer then a couple of seconds at a time they will work, just be careful, Something like this if you are trying to stay small would be a better option. http://www.hobbypartz.com/98p-20c-800-2s1p.html with a charger like this will work http://www.rcplanet.com/Venom_Lipo_B..._p/vnr0653.htm Last edited by abadk9420; 04-07-2011 at 09:20 PM. |
04-08-2011, 08:46 AM | #10 |
hes just using a miniqlo, not a high amp motor and servo i think he would be fine.
04-10-2011, 05:01 PM | #11 |
hey guys, another question..how long will it take for a 7.4V 180 mah LiPo to charge? the charger has a chrge rate of 150 MAH. thanks
04-10-2011, 07:49 PM | #12 |
Little more then an hour
