04-08-2011, 01:24 PM | #1 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
| servo and bec prob
Ok I searched and found nothing. I just put a high voltage servo in my buddies LCC He has a DX3R with a sr3100 rx Xcelorin esc and 17.5 motor When I hit the throttle the steer goes back and forth like its steering crazy. What could be the issue? I have the CCBEC wired to the servo power leads, so the esc is powering the rx and the dig servo. Please help me out. And thanks in advance. |
04-08-2011, 01:31 PM | #2 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
is the servo ground wire (black) hooked up to the RX? sounds like a grounding issue. same reason we only pull the red wire from the signal harness on the ESC when powering the RX with the BEC |
04-08-2011, 01:33 PM | #3 |
Ground to the servo is hooked to the negetive battery lead. The way I always do it
04-08-2011, 01:54 PM | #4 |
I got it.
04-08-2011, 01:55 PM | #5 |
| What was the issue. Hope it was a simple fix he doesn't seem to want to admit i'm right , he hooked the ground wire up to the reciever and bam! works perfect. (aswell as pos/neg on the BEC) glad you got it going, just busting your chops Last edited by fred0000; 04-08-2011 at 04:06 PM. |
