04-11-2011, 06:37 PM | #1 |
Newbie Join Date: Mar 2011 Location: tracy city
| Battery & Charger mix or not
Well think I having trouble with my Battery now. I bought at a local hobby shop and he said it was a good setup. Now cant seem to get my LIPO battery to charge. put it on charger and it says it is charged in a few minutes but its making my crawler run crazy. Shop sold me a LOSI 2-cell 7.4V LiPo battery part#LOSB9868, he then sold me a vision ultra dynamite charger to charge my battery with. well I have charged it about 4 times at a 3.6A and done fine, from what I read on instructions that is what I was suppose to do. I also read only to use losi charger. Any input welcome.
04-11-2011, 06:58 PM | #2 |
Doesnt look like that charger will balance your lipo. I would recommend getting a charger that will balance your cells or you can buy an external balancer to use with your charger. Im not sure exactly what the problem you are experiencing is...Can you tell us what the problem is? |
04-11-2011, 07:19 PM | #3 |
Charging most LiPO's @ 3.6A is NOT good for the life of them. Take the time and only use 1A. Also, you can use ANY brand charger for ANY brand battery. One makes volts, the other accepts it. Balance charging LiPO's is also a good thing. What rig is this in? What ESC? Does the ESC have a LVC (low voltage cutoff)? You are overcharging the pack and "may" be overdischarging it. |
04-11-2011, 07:57 PM | #4 | |
04-11-2011, 07:59 PM | #5 | |
04-12-2011, 07:55 AM | #6 |
Rock Stacker Join Date: May 2010 Location: Canada
Charging a LiPo at 3.6A is perfectly fine, if it's a 3600MaH. You can also charge LiPo's at much higher rates if the packs are rated for it. Generally you want to charge a LiPo at 1C (1 X it's capacity). I charge some Thunder power 6S 4400MaH 65C at 20 amps all the time at the field. Doesn't look like your charger will balance LiPo's either, which is pretty important. I would bring it back to the LHS you purchased it from and get one that will, or purchase a cell balancer that will work with your application. You also don't want to discharge a LiPo under 80% of it's capacity. Over time this will shorten the battery life significantly. |
04-12-2011, 08:22 AM | #7 | |
RCC Addict Join Date: Oct 2008 Location: Tyler, TX
Some newer lipos allow up to 5c charging as well. However any lipo is good for 1c. In fact hyperion chargers (hands down one of the best) automatically charges your lipos at 1c when you put in the information on capacity and cell count. No need to buy a losi charger though, that is just BS and losi trying to sell you more crap. In fact, the losi lipo charger is the same one that can be had on hobbycity.com for about a third of the price, of course it doesn't have losi stamped on it, but oh well. Losi Charger: Hobbyking/Hobbycity Charger: Last edited by TexasSP; 04-12-2011 at 08:26 AM. | |
04-12-2011, 01:35 PM | #8 |
Quarry Creeper Join Date: Dec 2008 Location: Australia
Are you sure you have the battery type selected correctly in the charger? You can also select Life or LiIon, both these will still charge the pack to its correct current but put a much lower voltage in to the pack. Life would be 7.3 volts when charged and LiIon would be 8.2 volts (I think) when charged. |
04-12-2011, 01:42 PM | #9 | |
Are you running the stock 27mhz radio? | |
04-12-2011, 10:51 PM | #10 | |
09-24-2013, 10:46 PM | #11 |
| Re: Battery & Charger mix or not
Been while but found the problem it in the radio Dx3e. No problems now for past couple years. thanks for the help battery charging right now too.
09-24-2013, 10:58 PM | #12 |
Rock Crawler Join Date: Oct 2012 Location: Trail B.C.
| Re: Battery & Charger mix or not |
09-24-2013, 11:51 PM | #13 | |
| Re: Battery & Charger mix or not Quote:
True, but a resolution has been had, thus it's a good thing. | |
09-25-2013, 12:10 AM | #14 |
Just having a little fun with it
09-25-2013, 07:02 AM | #15 |
