04-12-2011, 04:18 AM | #1 |
Pebble Pounder Join Date: Aug 2008 Location: marlborough, ct
| Venom fireball 50t
does anyone know the factory timing? Or which line is 0 on the case? thanks
04-12-2011, 09:21 AM | #2 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
No clue on the factory, but zero usually will line up between the mounting holes on the bottom. Later EddieO |
04-12-2011, 05:45 PM | #3 |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
Factory timing is 0*. The timing mark on the end bell lines up with the small dents just under it, thats 0* EDIT: Pic of 0* (yes its a fireball, just changed the brush hoods) Last edited by WIDELOAD; 04-12-2011 at 05:55 PM. |
04-15-2011, 02:30 AM | #4 |
currently i have the leads from the dig wired backwards on my rear motor and even with staggered gearing, have a little too much rear stall. Should i time it 180 and put positive back to positive or does is not matter. Also just wanted to toy with timing to get the stall just right.
04-15-2011, 04:02 AM | #5 |
It wont make any difference if you 180 it. It would just make your pos & neg wires match. I wouldn't use timing to compensate for stall. Increasing the timing increases RPM yes. But it also increases heat, comm & brush wear and decreases efficiency. Change pinion's instead. Better way to do it IMO. |
04-16-2011, 06:43 AM | #6 |
currently running a 15t/14t setup runs awesome. Just a little anal and what to dial in better. Still def nothing to complain about. If anything a little stall gives and advantage to a skilled driver.
