Thread: servo voltage question
Old 04-12-2011, 08:06 PM   #1
Question servo voltage question
ok so i have a castle bec that is set at 7.4 volts. it is coneted to a xl5, a futaba s9303 servo and a novaksmart stop. every time im climbing something(like a wall) the servo starts to glitch and so does the throtal, is this becuse of the voltage? this is being run in a lcc with a 55t motor.
minnesotamudder is offline   Reply With Quote
Old 04-12-2011, 09:21 PM   #2
Sounds like a coincidence to me. It sounds like a either a damaged reciever or radio.
It usually runs fine is offline   Reply With Quote
Old 04-12-2011, 11:36 PM   #3
Did you/can you try a different battery pack?
What radio are you running (brand & model)?
Charlie-III is offline   Reply With Quote
Old 04-13-2011, 06:15 AM   #4
i havnet tied a diff batt yet but i will today, im runnig a traxxas 27mhz radio and reciver.
Old 04-13-2011, 04:59 PM   #5
ok so i tried it with another battery and its doing the same. also it sometimes gliches when going in reverse, and it some times gliches just siting in place. so im kinda stumped here.
Old 04-13-2011, 06:47 PM   #6
My guess is the added load of a climb adds to the EMF/RFI (basically, electrical "noise") that is swamping the RX signal.
If you are careful of antenna placement as well as ESC & BEC, you may limit it to an acceptable level.
The other choice is to go to a 2.4ghz radio.
Old 04-13-2011, 06:57 PM   #7
ya im going to get a dx3c when it comes out next month
