04-13-2011, 02:43 PM | #1 |
Newbie Join Date: Nov 2010 Location: norway
| ezrun upgrade
hi..i have the ezrun 32t crawler combo,but think it lacks a bit wheelspeed and power...so i wondered what motor that would be a good replacement? wouldd like to order from hobbyking..http://www.hobbyking.com/hobbyking/s...dProduct=11175 would this one work? without smoking my esc?or other suggestions from hk?
04-13-2011, 05:17 PM | #2 |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
That motor would work, but would smoke your esc. The EZrun esc is rated at 35a continuous, so you need to look for a motor that is around this spec. Be aware as well that the higher KV motor you use the more stutter & cog you will get. What voltage are you running? If you're not already, you can run 3s on those EZrun escs which will give it a bit of a kick in the nads. |
04-14-2011, 12:39 AM | #3 |
okay.. im running a 8.4 setup...may just try with a 3 cell..
04-14-2011, 04:39 AM | #4 |
Quarry Creeper Join Date: Dec 2009 Location: jackson,tn
hobbypartz has a sensored setup that works fine, get the 3300kv sensored motor, on 3s it kicks hard and still farily good with crawling. nothing like a brushed motor, but it's better than completely cogging with you. i ran it for a while
04-14-2011, 01:15 PM | #5 |
Rock Stacker Join Date: Jan 2011 Location: Sundre, Alberta
that motor you linked is kinda a speedster isnt it?? (im new to brushless) |
