04-15-2011, 11:22 AM | #1 |
Newbie Join Date: Apr 2011 Location: France
| Sidewinder V2 super hot on 3S with brushed
Hi, first let me introduce myself, I'm a french noob crawler. I've spent quite some time lurking on this forum(Thanks guys for the good advices I could find here thank you as well for turning this little hobby into a money hole ) I own a ax10 with gc3a,sv2 esc,cc bec ,hh torquemaster 45T. The torquemaster is my 3rd motor, I used to have a silvercan which died. For the last month I have been using a revolver black( which is a brushless) on 3S with no issue but the cogging at low speed, I just switched to the torquemaster today since I like brushed better and the sidewinder gets hot very fast when i use the 3S. It happened as well with the silvercan , which I ended up using only with a 2S. Any help or advice would be greatly appreciated. |
04-15-2011, 12:07 PM | #2 |
Whats your gearing (pinion/spur)? Gear mesh to tight? Does the motor get hot? Drag in the drivetrain? Everything set right via Castlelink? I've never felt any of mine reg Sidewinders even get warm in a crawler. |
04-15-2011, 12:16 PM | #3 |
I have the stock ax10 gearing 14/87, I have upgraded my tranny gears by all metal ones but there is no drag or bind in it nor in the drivetrain. I used castlelink to set it to brushed, auto lipo, crawler 213%.. nothing special. The motor gets warm on 2S after driving for a long time. I drove it this afternoon for about 2 hours, 10 mins with the 3S and then the esc cut because of it's temperature. The remaining time, nearly 2 hours was with a 2S, the esc was cold and the motor at most was warm. What puzzles me is that i don't have that issue when using a 2S or a brushless with 3S. It only happens with a 3S and brushed that the sidewinder gets so hot that it cuts. edit: On a side note, my crawling mate has a CR01 with a sv2 as well and has the same issue when I lend him a 3S. His sv2 gets hot super fast as well and then cut. He has a CR tuned tamyia motor. we have no problem in 2S. odd ... Last edited by steppinrazr; 04-15-2011 at 12:55 PM. Reason: added informations |
04-15-2011, 01:36 PM | #4 |
Quarry Creeper Join Date: Dec 2010 Location: vegas
04-15-2011, 02:23 PM | #5 |
Quarry Creeper Join Date: Aug 2010 Location: Sheboygan
When I built a Creeper for my dad I went with a Sidewinder V2 and 3s as well. Ran up at HobbyTown USA in Oshkosh and the esc was slightly warm at best. Neither the motor or esc got hot. I set his up as brushed, 3s cut off and 213% drag brake .
04-15-2011, 02:51 PM | #6 | |
if 3s would fry his esc which is rated to run on 3s and fry a brushed motor on 3s why do so so many ppl run 3s with no problem, including myself. i would contact castle directly about this problem as it seems there are still bugs with the new sv2. on my original sidewinder i run a cheap integy 16t motor on 3s in my cr01 or sc truck all the time and the motor is fairly warm but the sidewinder is just barely warm and that motor has yet to fry, it just eats brushes because of its speed. | |
04-15-2011, 03:01 PM | #7 | ||
I wanna be Dave Join Date: Sep 2008 Location: four o six
was thinking the same thing, these motors/esc/batteries aren't the same as yesteryear. some guys are running 4S with 35T motors or pullers. I have run 3S with no over heat issues. second on contacting Castle...Charles is very good to deal with (as is the whole group over there) Make sure you have brushed set up with your ESC control on the computer, timing set to O...just double check. Hope you get this figured out. | ||
04-15-2011, 03:06 PM | #8 |
I just have my esc plugged in the castlelink and everything seemed fine. I see everywhere on the forum that people are using 3S and brushed motors on a sidewinder. Hence me being puzzled. What really bothers me , is that i have no issue with a bl or with a 2S and a brushed. and that i have tried a 3S on my friend sv2 and he had the same problem. As you suggest i'll send a mail to cc and see what they think of it. I'll keep you posted. |
04-15-2011, 03:10 PM | #9 |
I had alot of heat in my BRXL (very similiar to sidewinder) with 3S and the drag brake set so high. lower your drag brake to 30%-50% and alot of your heat will go away. mine did. and it will still hold the truck on the side of a hill. i was running the identical motor as you as well. when i had the drag brake set that high the motor would also make all kinds of grunting noises setting still, and shoot fire out the endbell. lowering the drag brake fixed all that. heat as well. |
04-15-2011, 03:15 PM | #10 | |
Thanks for the tip, I hope it will fix the problem! | |
04-15-2011, 03:49 PM | #11 |
I worded my words wrong? I was trying to say that if the esc is getting hot there is something wrong and that it could fry or some type of damage could result from it. Thats what I meant to say.
04-15-2011, 04:10 PM | #12 | |
Asw27x is running a 35T brushed on 3S (for over a year) in a Venom Creeper (AKA, shafty) and I am running a Bully MOA (single CC MM with a servo dig) with 2 brushed 40T motors on 3S. We can avoid issues as well....... OK, kidding aside.....I believe there is another issue for the OP. | |
04-15-2011, 06:15 PM | #13 |
RCC Addict Join Date: Aug 2009 Location: Earth?
Got B.E.C.?
04-15-2011, 06:20 PM | #14 | |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
You better not tell the 35t Handwound Brood motors I have been running on 4s for the last couple of years. Mamba Max takes it like a champ. Are you running an external BEC? If not I bet money thats the issue. | |
04-15-2011, 06:39 PM | #15 | |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
04-15-2011, 08:45 PM | #16 |
04-17-2011, 07:20 AM | #17 |
Here are some news: I tried yesterday what was mentionned and replaced the 213% crawler drag brake with a 50% drag brake. I could run my 2200mah 3S fully without over heating the esc which stayed at "worst " warm. I wasn't on my usual course, and the place was much more tame so maybe that's also why it didn't heat. I'll see tomorrow on a harder course if it still doesn't heat. The hold is still good at 50% drag brake on forward. but if i reverse , the hold isn't that great (I know i'm not supposed to reverse...) |
04-21-2011, 05:13 PM | #18 |
RCC Addict Join Date: Nov 2009 Location: New Wilmington, PA
I'm having the exact same problem. I run a 7t puller, with a 3 cell, and a BEC. Never had a problem with a revolver brushless. I'm calling castle in the morning. 1 : Brake/Reverse Type Option 3 : Forward/Brake/Reverse 2 : Brake Amount Option 4 : 100% 3 : Reverse Amount Option 4 : 100% 4 : Punch Control Option 5 : Disabled (D)* 5 : Drag Brake Option 5 : 40% 6 : Throttle Dead Band Setting 4 : Very Small - 0.0500 ms 7 : Voltage Cutoff Option 2 : Auto-Lipo Or Option 5 : 9 8 : Motor Timing Option 1 : Lowest 9 : Motor Type Option 2 : Brushed Reversing |
04-21-2011, 05:40 PM | #19 |
I contacted CC last week and still haven't received any news. I dropped them another email yesterday. After trying the drag brake at 50% it seemed to be better , but once i really tried on my usual crawling spot, it appeared that it made no difference with the 213% one. The esc heated fast , glitched and cut. |
04-21-2011, 06:48 PM | #20 |
I'll post up here what I find out. I hope they aren't closed tomorrow for good friday.
