04-26-2011, 06:02 PM | #1 |
Quarry Creeper Join Date: Sep 2009 Location: Scottsdale
| 3s vs 4s on 35turn Motor
I have a SCX10 that has a full interior cage and tube bed. I would like to run two batteries, one located on each side of the tranny under the floor (on my sliders). I am running a Sidewinder with a silver can 35 turn motor and I have been running small 1350 mh 3s venom lipos. I can either set it up to run 2 1350 mah 3s batteries to get a total of 2700 mah or I could run two 2100 mah 2s batteris as a 4s saddle pack. With all that being said, I have read that the Sidewinder will work OK on 4s. What difference would I really see on the 4s setup vs the 3s setup? Thanks, |
04-26-2011, 06:09 PM | #2 |
A 33.33333333% increase in speed and power. Say a motor turns at 1000kv, 2s would max at 8,400 rpm, 3s at 12,600 rpm and the 4s would crank out 16,800 rpm.
04-26-2011, 09:37 PM | #3 |
Quarry Creeper Join Date: Mar 2011 Location: Houston
***25% more power
04-26-2011, 10:25 PM | #4 |
Well, I haven't had a chance to run my rig yet but it is getting kinda heavy. I'm am thinking that the increase in power will be nice. I don't think I need to much speed so I may have to change up my gearing a little. It would be nice for comps, and I can always put in the 3x lipos for longer trail runs. |
04-27-2011, 09:21 AM | #5 |
it will have noticable power and speed increase but will eat throught the brushes and comm much faster and since its a silvercan you will need to replace it sooner so i would wire 2 3s in parallel for longer run times
04-27-2011, 10:07 AM | #6 |
RCC Addict Join Date: Oct 2008 Location: Tyler, TX
You should also lower your pinion a tooth or two or increase spur size to compensate. Most likely a silver can 35t will heat up quite a bit on 4s.
