04-27-2011, 12:21 AM | #1 |
Quarry Creeper Join Date: Dec 2009 Location: Brentwood
| motor keeps bogging!
well, got a 27t trinity motor for my scx10. now that its hooked up. its bogs out really bad from a dead stop. my esc can handle down to a 12t and battery is fully charged. its like its not getting enough power. it works fine when i pick it up or ease on the throttle. but when i floor it, thats when it bogs. what do you think it could be? brushes are fine comm is fine conections are fine please help! i really wanna get my truck running! thanks! |
04-27-2011, 01:17 AM | #2 |
Rock Crawler Join Date: Dec 2005 Location: West Omaha
Geared to high. Use a lower tooth count pinion.
04-27-2011, 07:09 AM | #3 |
What ESC?
04-27-2011, 11:52 AM | #4 |
04-27-2011, 11:52 AM | #5 |
04-28-2011, 12:40 AM | #6 | |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
But in saying that, it sounds like the battery cant handle the instant amp draw the motor is asking for when you punch it. I had the same symptoms with my comp rig ages ago and traced it back to old batteries that weren't giving enough discharge. Try putting the spur back to stock. If that doesn't work, try a different battery. | |
04-28-2011, 03:10 AM | #7 |
Rock Stacker Join Date: May 2009 Location: Wausau
04-28-2011, 04:38 AM | #8 |
It could be a couple of things, already mentioned. 1-You likely dropped the motor wind from stock (from a ~55T to 27T), thus it WANT's to spin faster, but you had the original motor geared for faster. The 27T motor is having issues spinning up due to the gearing. 2-You battery may not be up to the task of the lower turn motor. How is your gear mesh? If it's too tight, it can also make the rig do what you are describing. |
04-28-2011, 11:22 AM | #9 |
Rock Crawler Join Date: Dec 2010 Location: Beaumont Tx!
Gear mesh is one thing to check. Pick the car up off the floor and punch it, if it cuts out then you are having a current problem. What plugs are you running, Tamiya? What battery?
04-28-2011, 11:25 AM | #10 |
| gear mesh is perfect. it works fine when its off the ground. and running deans. on venom, racers edge 6 cell nimh packs
04-28-2011, 11:27 AM | #11 | |
so i installed the 27t on same gearing and bogs to much. im goin to try the stock gearing and see if its better and gear mesh is perfect. | |
04-28-2011, 11:29 AM | #12 | |
i might try a lipo out | |
04-28-2011, 11:37 AM | #13 | |
but this gearing is way too high! and IMO nimh's suck compared to lipos | |
04-28-2011, 12:02 PM | #14 |
Quarry Creeper Join Date: May 2009 Location: brentwood
| Defiantly switch to lipo, something over 30c discharge rate would be just fine! I know the initial cost sucks but you won't be disappointed!
04-28-2011, 12:40 PM | #15 |
Newbie Join Date: Sep 2009 Location: quebec
When you make any change on electric setup do not forget to re-calibre your esc.
04-29-2011, 02:20 AM | #16 |
04-29-2011, 02:21 AM | #17 | |
yea ive been wanting too. but its just to pricey for me right now. expecialy a charger. but i think im gunna start saving for it! | |
04-29-2011, 09:24 AM | #18 | |
05-05-2011, 01:46 PM | #19 |
yea so i just put the stock gearing on (87t, 20t) and still does the same thing. should i switch out the stock bullet conectors for some deans?
05-06-2011, 08:43 PM | #20 |
| Yeppers......get rid of any bullet or Tamiya connectors (with the exception of the heavy duty CC style bullets). The cheaper bullets & Tamiyas will degrade over time and add resistance to the connection. This makes heat which makes it all worse.
