04-29-2011, 07:05 PM | #1 |
Quarry Creeper Join Date: Apr 2011 Location: United States
| DX3C radio dig question
I'm new to crawling and even newer to the dig. My dig is on the way but i still have a 2 ch radio. With the dx3x how do you engage/control the dig? does the radio program the servo for the 4 wheel, 2 wheel, and rear lock. Can a 3 way switch be simply wired to select the 4,2 or locked?
04-29-2011, 07:24 PM | #2 |
Quarry Creeper Join Date: Jul 2009 Location: West GA, USA
Basically, you'll be able to set the endpoints for the dig servo just like you set the endpoints for the steering servo. If the DX3C has a 3-position 3rd channel, you'll be able to set 3 points on the 3rd channel. It's something you have to tinker with to get it set up correctly. I haven't seen the DX3C in person, but it looks like there's a button on the radio that controls the 3rd channel, just like most 3ch radios. The manual is not on the Spektrum site yet. If you are using this on a shaft truck with mechanical linkage, then it's easy to set up. I'm not sure about MOAs. Hopefully that will get you started. |
04-29-2011, 08:05 PM | #3 |
yes its a single motor shafty. Does anyone know if it has a 3 position 3rd channel?
04-30-2011, 07:13 AM | #4 |
Rock Stacker Join Date: Jan 2011 Location: Boise
THe DX3C does have third channel just like the DX3E. The # in the model means third channel. The DX3C is on the Spektrum website and will show you the basics.
04-30-2011, 11:11 AM | #5 |
I know that it has 3 channells, but is the third channell a 3 way or 2 way switch?
04-30-2011, 06:20 PM | #6 |
Quarry Creeper Join Date: Jan 2010 Location: USA
04-30-2011, 10:33 PM | #7 |
thanks, I'd hate to buy a radio that didnt work.
05-01-2011, 10:02 AM | #8 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
spek has a DX3C out now ??? ....where is the DX4R yet ??? .........bob .... |
05-01-2011, 11:48 AM | #9 |
Rock Stacker Join Date: Feb 2010 Location: Rome,Italy
i think that the 3rd channel of the dx3C work in the same mode of mine DX3R,so yes,you can able to use all the 3 position (lock,unlocked and free spind) of you dig |
06-11-2011, 11:39 AM | #10 |
Newbie Join Date: Feb 2006 Location: Alabama
I have not been able to adjust end points for my 3 position dig. I have hooked up my servo and can move it the three positions, but need to limit travel. Any ideas? |
06-11-2011, 05:58 PM | #11 |
06-11-2011, 06:42 PM | #12 |
Ive gone through it... but I R Dum http://www.spektrumrc.com/ProdInfo/F..._Manual_EN.pdf Any help would be great! |
06-11-2011, 06:47 PM | #13 |
I guess page 8 explains 'Travel'.... damn i need to read more carefully or drink less or more.... So selecting Ch3 (eg.. 'E') i would adjust the % left and right? |
06-12-2011, 06:52 AM | #14 |
Thanks for the link. Yes, the travel adjustment on page 8 is what you want to use to adjust your end points. In the travel screen, select Aux, and then set your H and L values. This is also is referenced on page 11 when assigning a switch to Aux 3P (which I assume you are using for your dig). If you need to adjust your center point as well, it looks like you can do this with the sub trim setting on page 10. Let us know how it works out! |
06-12-2011, 07:14 AM | #15 |
Thanks for the help! I'll try it today, im anxious to get the rig back together |
06-12-2011, 01:07 PM | #16 |
Sorry to the OP for the hijack... Well... thanks wantAsummit for pushing me to read the manual After a bout an hour of messing with the settings, lenght of linkage and stuff... it moves to all 3 positions smooth as butter. VP makes some nice but expensive bling! The MIP cup will need some massaging or the bracket mounting holes sloted and bracket rotated up a tad. Thanks for all the help RCC!!! |
