05-01-2011, 09:37 PM | #1 |
Pebble Pounder Join Date: Jan 2011 Location: london,England
| Running lipo,s to low
Hi I,m running two fxr,s with a ex bec and a couple of times I have left it plug in and have killed the lipo,s are the cut of switch in the esc ment to work with ex bec or is there any thing I can do to stop this. Thanks guys |
05-01-2011, 09:48 PM | #2 |
Rock Stacker Join Date: Dec 2009 Location: stockport ohio
just make sure to unplug the battery each time your done for the day, im not sure about the cutoff but im sure somone will give you a better answer than I can.
05-01-2011, 09:51 PM | #3 |
Defy Gravity Join Date: Nov 2009 Location: wells, mn
you're still powering the receiver or servo depending on how you wired it. unplug after you're done, and you won't have this issue. even turned off, electronics still draw power, so even if you just used the fxr internals, you'd still have that problem if you left it plugged in.
05-02-2011, 12:12 AM | #4 |
Just hard wire the FXR switches on all the time and tuck the wires in the case. That will force you to pull the battery to turn off the rig every time and they wont get in the way. |
05-02-2011, 07:02 AM | #5 |
05-03-2011, 03:09 PM | #6 |
Newbie Join Date: Jan 2010 Location: Up s**t creek with no paddle
X3... as a wise, (not so) old fellow-crawler once posted, MY ON/OFF SWITCH IS A DEANS CONNECTOR. Words of wisdom if I ever heard'em.
05-03-2011, 04:19 PM | #7 |
Quarry Creeper Join Date: Aug 2004 Location: Southwestern PA
I tried leaving the switch "on" on my Goat, with CC BEC powering the receiver, but I didn't like the electrical arc every time I went to connect or disconnect my battery plugs. I make sure to unplug the battery whenever the truck is not in use, but I also use the ESC's power switch to minimize the arc.
