05-07-2011, 11:11 AM | #1 |
RCC Addict Join Date: Oct 2007 Location: gervais
| rough estimate of run time?
so I have a 35t motor(think thats all I need to tell?) how long of a run would I get with a 3s 2200 mah 25c lipo?
05-07-2011, 11:26 AM | #2 | |
Quarry Creeper Join Date: Aug 2004 Location: Southwestern PA
bearings or bushings? worm gears? gearing? tire height tire/rim weight total rig weight any electrical accessories? Say you had worm gears, bushings, really tall gearing for top end, super tight gear mesh, really tall, heavy tires/rims on a heavy truck with lots of lights. a 3s 2200mah 25c Lipo would run maybe 2 minutes, then blow up probably. LOL! Same battery and motor on a really light rig with bearings, low gearing, no binding at all, shorter tires, no rim weight, etc... and you can run for half an hour or more... So we need more info than just battery size and motor turns to help you. | |
05-07-2011, 11:35 AM | #3 |
ya I wasnt sure lol thats why I added that insert lol, it's a axial axles and tranny, with gcm transfer case, my tires are the 2.2 mil spec with the 2.2 bead cut out and 1.9 beads put in its place, scx10 chassis, at the moment I think my rig weighs 4 pounds? no weight at the moment in the wheels, bearing and bushings, I could not tell you other than I switched the brushed in my new axiom motor into the 35T lol
05-07-2011, 11:36 AM | #4 |
Newbie Join Date: Apr 2011 Location: Norway
I have a 35t motor and a novak rooster crawler esc in my scx 10.everything else stock.I run about 2 hours on 5000mah 2s lipo so I will guess you can run about 1 hour.app...
05-07-2011, 04:11 PM | #5 |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
I run a 2200 3s & 45t in one of my scale rigs, on average i get about 1.5hrs on a trail drive before i need to switch it out. So you're probably going to get at least an hour. |
