05-08-2011, 01:02 PM | #1 |
Quarry Creeper Join Date: May 2011 Location: Battle Ground WA
| AE-2 Questions.
Hi all, I'm new to the RC crawler world, I picked up a RTR SCX10 trail honcho yesterday with the "new" AE-2 ESC. I'm running a Venom 5000mah 2s LiPO. The AE-2 supposedly has a LiPO cutoff built in but I'm having a very hard time finding much info on it. What voltage does it cutoff at? I noticed my truck was a little down on power so I hooked the battery to the charger to discover 1 cell was 3.1v and the other was 2.96v. Shouldn't the ESC have cutoff before it got below 3v?
05-08-2011, 01:09 PM | #2 |
i belive the cut off is when both cells reach 3.0 volts.
05-08-2011, 01:13 PM | #3 |
Quarry Creeper Join Date: Dec 2009 Location: At your moms,she says hi!
did you purchase it new? if so it is already setup for lipo cutoff,and yes it should have shut down before your voltage went that low.
05-08-2011, 01:24 PM | #4 |
Quarry Creeper Join Date: Feb 2011 Location: Vancouver, WA
The cutoff is set to auto from the factory which I believe is 3 volts per cell so 6 volts for a 2S lipo. Did you happen to leave your battery plugged in for an extended period before charging it? Even when the ESC is switched off it continues to draw power unless the battery is physically unplugged.
05-08-2011, 01:40 PM | #5 |
Thanks for the quick replies. Yes I purchased it new so cutoff should be enabled. I do not leave it plugged into the truck for extended periods of time. As stated I had been running the truck for a while, noticed it was a little low on power (instead of slipping the clutch when bound up, it would stall) and then put it on the charger. I've heard actual damage doesn't occur until closer to 2.5 volts, thoughts?. I'm thinking about picking up a Castle Link so I can up the cutoff voltage a bit since the ESC has no way of motoring each cell individually and 1 of the cells can dip below 3v before it cuts off. Also I assume it physically cuts power from the truck right? Or does it beep or something?
05-08-2011, 01:47 PM | #6 |
LiPO cutoffs will kill the rig when the TOTAL voltage runs too low. Thus, a single cell may be lower & be damaged. You are correct, a LVC does NOT know the individual cell voltages. If you balance charge the packs most of the time, you will have a heads up when one is going off. |
05-08-2011, 01:50 PM | #7 |
Castlelink would be a good investment you might be able to find a hobby shop that would adjust it for you. I'm pretty sure Tammies Hobbies in Beaverton would do it, they are the best hobby store in the Portland/Vancouver area for crawler/scaler parts. The esc cuts power to the motor but allows the servo to keep working.
05-08-2011, 01:54 PM | #8 | |
05-08-2011, 01:56 PM | #9 |
