05-08-2011, 09:44 PM | #1 |
RCC Addict Join Date: Aug 2010 Location: wherever paypal sais.
| tekin fxr?
Just installed mine w tekin 35t pro motor on 3s What pinions u guys running to prevent thermal shut down.. mine keeps doing it but only when steering is bound up. Do you have to activate the bec or no? its acting like the stock axial electronics plz help. |
05-08-2011, 09:54 PM | #2 | |
Rock Crawler Join Date: Apr 2010 Location: Kelowna, B.C., Canada
What vehicle are you running it in as that will help others help you on gearing. | |
05-08-2011, 09:59 PM | #3 |
More likely it's overgeared and when in a bind you have the volt gate open but it doesn't have anywhere to go so it heats up the FETs. The internal BEC will not cause it to thermal because as you increase the voltage you decrease the current (amperage). Without an external BEC the servo can pull enough current to starve the receiver but not thermal. That only happens when you overheat the power transistors (FETs). |
05-08-2011, 10:21 PM | #4 |
It a scx10 based scaler. Only 7 lbs ill look onto different steering setups to reduce the power it takes to steer. I'm not sure if its thermal overload or not it just is doing what the stock axial electronics do when the steering is bound which is the truck wont do anything till u reset the steering.. ill try to get some more info to further help.
05-08-2011, 10:43 PM | #5 |
You need an external BEC. Check out the Castle Creations 10a BEC.
05-09-2011, 12:45 AM | #6 | |
i noticed according to the real time thermal tracking that if i sit with the steering at full lock for any period of time the temp goes all to 6 flashing led's.... so gonna try an external bec to eliminate the esc all together for powering the servo... to keep the temps down also gonna switch to a 17 or 18t pinion... im gonna lose some wheelspeed but in the end i think it will be worth it. | |
05-09-2011, 07:37 AM | #7 |
Pebble Pounder Join Date: Aug 2006 Location: Raleigh NC
you need a External BEC. I ran into the same problem with mine a few weeks ago. I'm running the FXR, 35t HH on 3s. The FXR kept shutting down, installed the BEC for the servo and it has worked flawlessly ever since. Zack |
05-09-2011, 11:05 AM | #8 | |
Depending on the radio you have it should have EPA's (end point adjustments) for each channel. If not you will need to get yourself a servo stretcher (http://www.rcdude.com/servlet/the-13...cher-V2/Detail) you should be able to find them at just about any hobby shop or online hobby shop. | |
05-09-2011, 04:43 PM | #9 | |
Quarry Creeper Join Date: Mar 2011 Location: Kailua
I think it's the products you have, not very good for your application. I'll just take those off your hands and you can go back to your Novak stuff. Or I'll just trade you my stock axial ESC, HPI 35t motor and Hitech servo............. Castle BEC should help ya out. | |
05-09-2011, 05:39 PM | #10 | |
05-09-2011, 06:24 PM | #11 | |
05-09-2011, 07:45 PM | #12 |
Just adjust it until it hits a mechanical stop (aka it cant physically turn any farther) and just back it off a little bit so you dont burn out your servo. The extra steering is not worth re buying all your electronics every couple months...
05-10-2011, 01:47 AM | #13 |
castle bec installed works like charm and can still turn the way i want it to. esc does not heat up not one bit! thanks castle creations!! and thank you all for your help!! |
05-10-2011, 12:09 PM | #14 |
Pebble Pounder Join Date: Mar 2008 Location: El Dorado Hills, Ca
On 3s the BEC is already working hard to drop down the voltage. This coupled with a bound up crawler with a high torque servo will "amp out" the bec and will cause it to run hot/thermal. You made the correct change by adding a seperate bec. |
04-22-2012, 01:19 AM | #15 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
| Re: tekin fxr?
I've had the the same issue with mine in my KOH Jeep. I had some 2S batteries and went that route since it crawled better. Now Ive got this set up in my SCX F350 still on 2S with a 35T motor geared 16/87t and my servo is a Hobbico CS170. It worked fine in the KOH but in the F350 I get glitching ever so often and occasionally just quits working. Tonight I plugged in some LEDs into the RX and drove it for maybe 20 minutes. The ESC up and quit on me and it was flashing all LEDs and it was almost hot to the touch. I'm not sure what the deal is now. I checked the manual and it says with all lights flashing is lose of signal. But I'm not sure how that's possible when it worked fine before it shut off. Any help would be appreciated.
04-22-2012, 01:46 AM | #16 |
| Re: tekin fxr?
Will it calibrate? Are you running an external BEC? I doubt you are thermaling on 2s, none of mine thermal on 3s.
04-23-2012, 01:22 AM | #17 |
| Re: tekin fxr?
no external BEC. I haven't tried to reprogram it.
04-23-2012, 04:21 PM | #18 |
| Re: tekin fxr?
Try to calibrate it... Does it chime when you turn it on? Either way you need an external BEC. |
