05-13-2011, 01:52 AM | #1 |
Newbie Join Date: May 2011 Location: Uk
| High torque / Low speed recommendations for the following idea ?
This is bit off - topic but I thought Id come here and try an way to see if any one can help with an idea I have to try to give myself some mobility by using my e-walker with a motor. Which you can read more about this here below ( if you like ) http://endless-sphere.com/forums/vie...hp?f=7&t=18558 I want to be able to use this motor for rougher terrain, inclines or just for whenever i need it but also with freewheel , so that I can use manually ( freewheel ) or with the assist. My question is whether there are any controllers currently being used by folk here that would allow me to achieve these slow mobility speeds ( 1- 4 mph ) with a drill motor ( i.e. 18 / 24 v dewalt ) and gear ratio 1: 80 - or at least no bigger than 88 tooth sprocket ( unless i change my wheels ) The Specs for my kneewalker are as follows. ( 7.5 / 8 " wheel diameter , 29lbs knee walker and about 175 or 80 lbs of raw flesh i.e. me, ) Ideally Id rather have controller i did not have to programme unless it was unavoidable or cheap ( not over grand like some ) Someone on a robot forum suggested a analog controller such as this http://www.robotshop.com/analog-motor-controllers.html would be the best way to go , but im not really that well versed on electronics so have no idea how difficult something like this would be for a virtual beginner . Any way if any has any ideas or suggestions id be grateful to hear them. thanks for reading. melon |
