05-14-2011, 06:26 AM | #1 |
Rock Stacker Join Date: May 2011 Location: RC room
| Castle - SV2 issue
hi guys.... I got a issue from my SV2 in these few days. what I got is 3S lipo, 35t motor, 7955 steering servo, CCBEC. and white wire go for nag. and red wire go for pas. my story is the SV2 works fine few weeks ago, but it was not working since two days ago. I checked battery, motor, servo, and I reprogrammed the CCBEC and SV2(upgraded to 3.2 version) after I got the throttle issue two days ago. Then I did bind it with DX3R, and everything working except the throttle. When I push the throttle from DX3R, it got orange light from SV2 when it is natural, and forward shows green light, and reverse shows flash red light. I think it is correct working condition. However, it won't work at all even SV2 shows those lights when I push throttle forward or reverse, and just natural. Does anyone know how to solve this issue? on the other hand, actually, I have a extra SV2 and CCBEC, both of them are new. I did bind with this extra SV2, and it works perfectly as we know orange light when it is natural, and forward shows green light, and reverse shows flash red light. But, do not know what's going on now sorry guys, I am in hurry now, Please give me a hand thanks a lot |
05-14-2011, 07:07 AM | #2 |
Ah ha.....I believe the new CC firmware fixes the "white motor wire" issue. Thus you likely need to remove it & connect the black one. But, I also hear the new firmware is not great for crawlers and you can't backdate the firmware. I haven't tried it, it's what I read in this forum recently (this week?) |
05-14-2011, 07:19 AM | #3 | |
thanks man... but, I got the throttle issue when it was in 3.1 firmware before I upgraded to 3.2, then I still got same issue after I upgraded to 3.2 yesterday. well, it works fine few weeks ago when it was in 3.1 firmware, and I did not do anything during this period. ok....I will try to backdate the firmware or remove the white wire and plug black wire first. By the way, I also emailed to Castle and told them my throttle issue yesterday, I will post more info. if I receive their reply. Quote:
05-14-2011, 05:53 PM | #4 |
I did revert to the 3.1 firmware. and use white and red wire. but after I bind with radio, it got flash green light from SV2. does it means the ESC did connect correctly or ? |
05-14-2011, 06:16 PM | #5 |
Did you try to re-calibrate the ESC to the radio?? I'm not an expert on this, just asking questions. |
05-14-2011, 06:30 PM | #6 |
RCC Addict Join Date: Aug 2009 Location: Earth?
A Hammer.
05-14-2011, 07:48 PM | #7 |
I have two SV2 got same issue now. both of them has been ran once only. I reprogrammed both of them and revert it to 3.1 firmware and bind it again and again...about 10 times already First one as I said it still got flash green light on it after I bind it with radio. Does anyone got this issue before? and know how to deal with this issue? Second one, it cannot be connected by Castle link, when I plugged in the Castle link to SV2, and it didn't do anything, I can ONLY see the very tiny red light from SV2. Do you guys think this SV2 is broken? Hope some of u guys can help me otherwise I cannot run my C1 rig and C2 rig |
05-15-2011, 12:47 PM | #8 |
RCC Addict Join Date: Nov 2009 Location: New Wilmington, PA
sounds like CC needs to look at the V2 parts a little more closely, they are having some problems... mine, and several others on the board. I'm gonna call them again on monday.
05-15-2011, 01:22 PM | #9 |
Quarry Creeper Join Date: Dec 2008 Location: Australia
Can I suggest trying several things all at once here. - Go to a New and unused Memory in DX3R. Bind TX/RX. Go to the System menu of the radio and then to the RESET Function then Parameters and click the scroller button. Move the steering to full right then left once or twice, move throttle to full brake and throttle once or twice then scroll to save then confirm YES save. Page 26 of the manual for more information on this. - Replace the red wire in your SV2 and connect to CC Link then reset to factory default settings under device settings. Change the motor type to brushed reverse and set the arming time to 2.5 seconds, leave the rest until you find out if this works. - Remove everything from else the receiver and connect just the SV2. Calibrate the SV2 and see if it works. A few things that can happen is changing setting in your radio since the last time you used it. You may have changed something and dont remember or one of your pals might have changed something, so going with a fresh memory in the radio clears this up as being the problem. Some of the things that could have changed in the radio are the Frame Rate settings, Sub-Trim, end points and most importantly the calibration of the radio. If someone plays with the calibration of the radio and doesnt save it because they get scared and dont know what they are doing it will screw your radio up until you do it correctly. IMO this feature should be hidden in the DX3R. This is what it says in the new DX3R Pro: "Saving incorrect calibration data may cause radio to operate different than expected". Removing the BEC and servo from the receiver also removes this and the servo from the posibilities of these being the problem. Changing the setting on the SV2 to default will also fix any programmed functions you may have changed incorrectly. The arming time is something I learned with my Spektrum gear when I use to run it. In built up area's of high 2.4ghz signals I found that my DX3R would become slow to connect to the receiver. Just having a phone with 2.4ghz sitting next to the radio or in your pocket can cause havoc. If the receiver and radio dont connect before the ESC tries to arm then the ESC just wont arm. Changing the arming time to 2.5 seconds gives the radio plenty of time to connect then lets the ESC connect there after. |
05-16-2011, 11:03 PM | #10 |
well, I emailed to Castle Creations(support@castlecreations.com) last Sat. but, they haven't replied my email yet |
05-17-2011, 05:44 AM | #11 |
Rock Crawler Join Date: Feb 2010 Location: Chapin, South Carolina
My problem was that I needed to swap the black wire with the white wire. If you havn't tried this, I'd just take the white wire, without the black wire attached and touch it to the area it goes and hit the throttle lightly. If it powers, that it the problem.
05-18-2011, 10:26 PM | #12 |
well, right now, these two SV2 are not working at all. Do u think Castle has a good customer service? hahahaha I emailed them last Friday, and haven't receive any reply...OMG |
05-19-2011, 01:43 AM | #13 |
Rock Stacker Join Date: Dec 2009 Location: Terre Haute
When you say you updated the firmware from 3.1 to 3.2, are you talking about the Castlelink software version? This is not the firmware versions. When you updated the software, it may not have updated to 3.2. I had this problem, and emailed CC. Their response was to install the software in a new folder instead of overwriting the original folder. This did the trick for me. It is a registry problem in Windows. Start your Castlelink software and click on "ABOUT" under the "Help" menu and verify that the software version is actually 3.2. What happens is that you run the 3.2 (or later) update, but the software remains at 3.1. The Firmware versions are NOT 3.1 or 3.2, that is the Castlelink software versions. Here are the firmware revision numbers for the SV2: http://www.castlecreations.com/downl...idewinder.html. Latest firmware is 1.32. I updated my SV2 to the latest firmware and did not have any issues. It also fixed the white wire issue. Hope you get this worked out soon, I know what you are going through! You might send another email or just call them. |
05-19-2011, 04:29 AM | #14 |
RCC Addict Join Date: Mar 2010 Location: Alburtis
05-19-2011, 06:08 AM | #15 |
I'm running CastleLink version 3.3 with no issues on XP Pro. Sticking with my 1.24 firmware though......(MM & Micro Pro). |
05-19-2011, 07:39 AM | #16 | |
RCC Addict Join Date: Oct 2008 Location: Tyler, TX
They have excellent customer service as can be affirmed but many people on this board. | |
05-19-2011, 04:18 PM | #17 | |
thanks for this info. yes, I was talking about the Castlelink software version, and I did upgraded to 3.2 version after I connect with SV2. is it gonna affect the SV2 ESC? I will double check with SV2 later tonight after I get home... thanks a lot Quote:
05-19-2011, 04:19 PM | #18 | |
thanks Quote:
thanks | |
08-05-2011, 05:14 PM | #19 |
Rock Crawler Join Date: Jan 2011 Location: Portugal
Any news about this? I'm looking for an ESC and the SV2 was an option but I have been reading about a lot of trubles... |
08-06-2011, 06:05 AM | #20 |
