05-16-2011, 09:36 AM | #1 |
Quarry Creeper Join Date: Apr 2009 Location: Akron, IN
| Battery wiring question---
I'm currently running 2S 800mah lipos on my rig b/c I think the biggest I can handle (size wise)...god that sounds wrong lmao...is a 2200mah. I'm thinking/wondering...can I wire the two 800mah together to get a total of 1600mah but still be 7.4? On my MERV I ran a couple lipos that were 2S wired into a Y connector then to the ESC and all was fine, but I wasnt sure if I can do the same with this? I just dont want it to be 4S lol.
05-16-2011, 09:58 AM | #2 |
Pebble Pounder Join Date: Apr 2011 Location: DOWN SOUTH!!*LONESTAR*
someone just posted something like this just the other day. you need to wire in parallel. cut the plugs off and wire the 2 blacks together then wire the 2 reds together and solder. then run 1 short red and 1 short black off of your new connections so it will be 3 wires together all the same color same with the red and put your plug on your ready to go. i guess its like a y going to 1 plug
05-16-2011, 10:21 AM | #3 |
| Thanks man! Thats what I was thinking but I wasnt sure if it would just end up being a 4S in essence or if I would end up running just a 2S with more run time.
05-16-2011, 11:43 AM | #4 |
Rock Crawler Join Date: Dec 2009 Location: Jersey Strong!
05-16-2011, 01:06 PM | #5 |
| Thanks. That diagram actually makes sense. I had something else in mind Glad I didnt do it . Go figure, the one time I dont use the search (I know, I know...) the answers are there |
05-19-2011, 05:41 PM | #6 |
And my next question... Can you safely charge both batteries at the same time with everything hooked up in parrallel? I have it wired so I can take everything apart easily, just be easier if I could keep them wired together.
05-19-2011, 05:51 PM | #7 |
Quarry Creeper Join Date: Sep 2010 Location: Central MN H-Town
use a parallel adapter so you can charge separately and balance separately, I would not permanently combine the two batteries. just my .02
05-19-2011, 06:30 PM | #8 |
I made a Y connector using two male connectors into a female so I can take everthing apart easily. I would rather charge the two wired together, but I wasnt sure if that would be safe? I just wasnt sure if the two would take a charge correct or if it would be like the "path of least resistance"? I plan on taking it apart to charge, just thought I'd get some opinions on safety wise. Thanks for the input though.
