05-19-2011, 09:31 AM | #1 |
Quarry Creeper Join Date: Nov 2010 Location: weeki Wachee
| venom pro charger ?
i have a venom pro charger, been using it for a couple years now. its showing on the lipo charge cell progress screen an extra cell thats non existant. im charging a 3s batt and it keeps showing 4 cells but the ghost cell is fluctuating in voltage like crazy and keeps stopping the charge and shows a voltage too low error message. i dont know what is going on. does anybody have any insight? this isnt the first time this has happened but it just started doing it recently. maybe its time get a new charger? or is it something not to worry about? im lost. i did however get a new balance block with the lipos. it did it again but i unplugged the balance block and plugged it back in an now it seems to be working fine. i did check all connections after the first time it gave me a low cell voltage error. but the low cell doesnt exist on my battery (ghost cell). yes the charger is set for 3s
05-20-2011, 11:46 PM | #2 |
We have 2 Pro Chargers, they work well. Our only issue was with the balancer, crappy solder joints inside caused one to short out when you plugged in a 3S pack, another didn't have good solder joints that left a pin disconnected. Some work with a small soldering iron and a magnifying glass made both balancers work well. Maybe open yours up and check the 3S port solder connections as well as conductive crap (loose solder bits) floating around inside the case. |
05-21-2011, 05:17 PM | #3 |
Rock Stacker Join Date: Nov 2010 Location: Jasper
You right on it with the balance block issue, Had mine about 3 weeks and it would not detect a battery. I emailed venom about it and they replaced it. Didn't really give me a cause but they did make it good. I have had it going on 3 years now with no problems.
