05-31-2011, 12:54 PM | #1 |
Rock Stacker Join Date: Apr 2010 Location: wrightwood
| Elite-850-74v-2S-Lipo-Pack
isthis a good battery pack for and ax-10? Its a play rig but does local comps once in a while. Also, will i have to install a lipo cut off? I run a tazer 12 t esc. brushed |
05-31-2011, 01:05 PM | #2 |
You need a lipo cutoff. Pack looks to be good for a crawler. CBP carries quality stuff. |
05-31-2011, 01:11 PM | #3 |
Thanks! do you have any reccomendations on a cutoff? are they hard to install? |
05-31-2011, 01:32 PM | #4 |
will this work for that battery pack? I want to order today.
05-31-2011, 01:33 PM | #5 |
I think Novak makes one, otherwise you need an ESC with cutoff built in.
05-31-2011, 03:35 PM | #6 |
Quarry Creeper Join Date: Apr 2011 Location: United States
does the tazer have a drag brake? I would say find a good esc, new or used that has a drag brake and lipo cutoff
05-31-2011, 04:13 PM | #7 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
my tazer 15 didn't have drag brake at all.
05-31-2011, 07:37 PM | #8 |
Rock Stacker Join Date: Jan 2011 Location: Yakima
A good cheap cost Li-Po ready ESC is the Losi LOSB9522. NOT LOSB9521 <----That one is NOT li-po ready. Just got one off ebay for 21.00 shipped to me new.
06-01-2011, 02:08 PM | #9 |
what exactly does a drag brake do? i searched a lil but not 100% sure on it. does it just stop the motor when the throttle is in the neutral positin? if so, mine might have that because as soon as i let off the throttle, my car stops right in its tracks.
06-01-2011, 02:12 PM | #10 |
Thats probaly just the brakes. Drag brakes hold the rig still while sitting on a hill. The last thing you want is for the rig to roll down the hill, you will flip. also you dont want to have to double tap to go into reverse because with instant reverse you can keep the truck from flipping sometimes. I'm assuming that esc doesnt have instant reverse but i dont know.
06-01-2011, 02:28 PM | #11 |
It prolly doesnt have drag brake then, and you have to double tap for reverse..
06-01-2011, 04:01 PM | #12 |
06-03-2011, 11:13 PM | #13 |
yep, drag brake is when your rig/controler is at neutral position on the throttle..."Brake" is applied to your motor so you won't roll forward or reverse. Very useful on a hill.
