06-05-2011, 07:54 PM | #1 |
Newbie Join Date: Nov 2009 Location: Asheville, NC
| Very simple question.
I want to know if the Team Losi mini peak charger (http://www.amazon.com/Mini-Peak-AC-W.../dp/B000BOHJO0) will charge either of these batteries: http://www.all-battery.com/tenergypr...onnectors.aspx http://www.all-battery.com/72v300mah...tors11204.aspx Thanks in advance. |
06-05-2011, 07:57 PM | #2 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
it SHOULD (dont take my word, but it does say 6 cell nimh's) work fine, but it would probably take several hours. you can buy a decent entry level charger for about the same kind of money.
06-05-2011, 08:06 PM | #3 |
RCC Addict Join Date: Jan 2008 Location: Lake Michigan
It will charge Nimh. But its output is 1.2a. Meant for charging the 1200-1400, 1:18 scale pack. It will charge those larger batteries, but very slowly. Prob in 3-5hrs. The peak detection should work, but not sure. You would have to adapt from a 2pin, non polarized micro to the Tamiya or Deans connectors. Contact (PM) "rcracer". He has three faster chargers for sale, cheap, $5-15. Or "dont slow down" has an even better one for sale for $25. |
06-06-2011, 01:04 AM | #4 |
Pebble Pounder Join Date: May 2011 Location: Spring
spend a little more money and get a decent charger. Your going to be charging your batts more than your going to get to drive your vehicle. My xp with small chargers constantly used for high capacity batts is that they will not last long before going poo on you. Thou I suppose if you go with setup you will be trickle charging your batts and they will last a very long time.
