06-07-2011, 08:33 PM | #1 |
Rock Crawler Join Date: May 2011 Location: SoCal
| Balancing problem
I just got a new Hyperion CX G3 Lipo. 2S 25C 1300mah. As received it powered my crawler. I just ran it a minute or so. Then went to charge it. Hmmm, the balancing plug is weird. It's a 5-hole plug, although only three holes have pins. So right number of pins and wires, but oversize connector. Plugged it into my balancing charger (Thunder AC6 clone), determined the battery voltage was 7.65V but the cells were about 1/2 volt different. After just a couple seconds the charger shut down with a connection error message. I tried just the balancing function, but got the same result. Maybe it's objecting to the "wrong" balance connector, but I don't think so. I think the cells are too far unbalanced. I don't have any other way to get them balanced. I'm currently charging the battery at 1A with the balance connector not connected. It will do that with no complaints. When the first cell hits 4.2V, will the other start to catch up? Or what do you recommend? |
06-07-2011, 08:51 PM | #2 |
Newbie Join Date: Aug 2006 Location: Terre Haute
I would make sure you have the black balancing wire lined up to the correct pin. If you are running DC to charge with most chargers have a minimum voltage input. If you can find someone with a blinky balancer they will let you borrow it should get the cells back into balance. Chad |
06-07-2011, 09:08 PM | #3 |
Update: I believe I was mistaken. Using straight pins and a VOM I just verified the two cells are perfectly matched. So the error must be the weird 5-pin connector when it expected a 3-pin. Note the pins are not consecutive in the plug body. They're in holes 1,2 & 5. I doubt I can withdraw the pins from the body without damaging them. That usually requires a special tool. The good news is since the battery seems to be balanced I can just stupid-charge it to 8.4V as use it. For a while. I suppose the solution is to find a proper connector and rewire the battery. Or bitch out Hyperion as to what's going on??? Why isn't there a normal 3-pin balancing connector on this battery? |
06-07-2011, 09:13 PM | #4 | |
06-07-2011, 09:17 PM | #5 |
Okay maybe the problem is the Hyperion battery is set up to be charged only with a Hyperion charger and they do things differently -- including the 5-pin connector. There appear to be adapter pigtails to fix my situation.
06-07-2011, 10:33 PM | #6 |
Yes there is adapters in fact I think my Hitech x4 came with that one. I knew there was something I was forgetting.
06-07-2011, 10:58 PM | #7 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
all this is on my website. www.team3sixrc.com BALANCE TAP CONFIGURATION GUIDE: Special thanks to RC Accessory for compiling this list. The following batteries all share the same plug style with the column header. Bantam, e-Station, and EAC boards have part numbers listed. Align JST XH EAC124 EAC134 EAC144 EAC154 3e Models ABF Air Thunder Align Beyonder Power BP Common Sense RC V1(rev Polarity) Common Sense RC V2 DN Power (rev Polarity) Dualsky Dynam EC Power E-Flight eFuel Electric Power Electrifly Energy EC Esky E-Watts Exceed RC Fusion Fully Max Gadex GE Power G-Force Grayson Power Hextronic Hi Models Hobby City Hobby Loong Hurricane Flight Systems HXT Imax Kong Power - Old Lightning Power 2S-5S Loong Max MaxForce Mega Power Mojo Mystery Nine Eagles Park Zone PolyNoOne PowerEdge PowerSource Protek Reedy Power Rhino SMC Tenergy (Rev Polarity) - Old Top Racing Tower Hobbies Trinity Turborix Vampower - New Venom WOW RC X-Caliber Zippy Thunderpower EAC129 EAC139 EAC149 EAC159 Apex DanlionsDesire Power DN Power 6S - New Flight Power / EVO Kong Power - New MPX Outrage Performance Plus Tenergy - New Thunder Power Vislero |
06-07-2011, 10:58 PM | #8 |
| Kokam JST XE EAC128 EAC138 EAC148 EAC158 Apogee (Rev Polarity) Clip on tap needs to be removed Core Graupner Kokam Neu Orion Avionics Vampower - Old Polyquest EAC123 EAC133 EAC143 EAC153 Enerland Enermax E-Tec Extreme Power Fliton Hyperion Impulse Max Amps Poly RC Polyquest True RC Xcite Not Supported by Bantam e-Station Connection Boards CellPro Revolectrix CellPro Revolution DN Power 6S Lipo-Uses (2) 3S taps - Old Flight Power - Old Lightning Power 6STanic (with Original Tanic Tap) RCA100 RC Car 7.4V Lipo Hard Cased Beyonder Power Chargery Power Checkpoint Duratrax Orion PolyNoOne PowerEdge Trackpower Tronics |
06-07-2011, 11:18 PM | #9 |
Thanks for the list. I emailed RCDude where I got the battery and he replied TONITE. Wow. He has adapter boards and adapter pigtails for my batteries. I just didn't know to order them when I ordered the batteries. |
