06-09-2011, 02:00 PM | #1 |
Quarry Creeper Join Date: Feb 2011 Location: Lynnwood
| FX-R Issue... Maybe
So a couple of weeks ago i was getting ready to run. My rig started to geek out so the day ended before it started! The front wheels would not spin unless i advanced them manually. I was told that it is the shim in the brush hood of my intergy 35T V11 (issue solved, got some HH Torquemaster 45T.) That's not the concern i have now. The front esc is not chiming when configuring settings (tried a factory reset). This is making me nervous that the ESC is done for. I found a thread on Tekin's forum that some one was having the same issue but the question was answered in PM not on the thread so i have no idea what it could be. To start, everything is hooked up correctly. I made sure that it was and asked tons of questions to make sure that i was doing everything correctly! (Thanks for all the answers guys! ) The ESC is programmed for 3S so i know its not that. I have ran 15-20 packs with the set up and have had no issues until now, including gears! So what exactly could it be? Im hoping its not fried. I cant find my receipt/order email and i have cut the switches off. So im assuming that the warranty is void now. Any help would be great! |
06-09-2011, 02:07 PM | #2 |
Quarry Creeper Join Date: Sep 2009 Location: Ukiah
have you tried the ecs with different motors I know I had a simular problem with my fxr in my ax 10, and it ended up being a hung brush that was the problem |
06-09-2011, 02:50 PM | #3 | |
Are you getting lights on the ESC? | |
06-09-2011, 03:08 PM | #4 | |
The light sequence is performs as normal, there is just know chime. Side note: Since you replied... I ordered power matching 45T a couple of weeks ago. I was under the assumption that one of the motors would have an R to indicate which motor goes where. Mine dont have those markings. Did i miss something when i was ordering? | |
06-09-2011, 03:39 PM | #5 |
Did you recalibrate the esc? Recalibrate them one at a time to the radio and see what that does. It sounds like one of them is not finding neutral. Are your radio throttle trims set to 0? |
06-09-2011, 04:40 PM | #6 | |
| I have reset to factory settings and then calibrated and adjusted the settings Quote:
That would be for the glitching of the motors right? I have hooked up a set of brand new motors that i get with that M2 setup. Never been ran and there was no glitching. But that did not solve the no chiming problem. I don't really care if its just the internal speaker that's not working, but i just need to know if that is a sign of something more than a small component being bad. Yes I would just hate to have to come out of pocket for another ESC. Thanks for the response Harvo. | |
06-09-2011, 04:49 PM | #7 | |
If you didn't specify a vehicle or timing, we send them both at zero timing and CCW rotation. | |
