06-09-2011, 08:14 PM | #1 |
Quarry Creeper Join Date: Jul 2008 Location: Sedro Woolley
| Nomadio React + 2 micro sidewonders + dig woes
Hey there guys iam in need of some help. i just recently made the switch from a punk dig and mamba max pro in my xr to 2 micro sidewinders and a nomadio react radio. both my esc's are calibrated to the radio. heres how my xr10 is setup react radio dsm 1 spektrum rx 3 channel 2 cc micro sidewinders (both running v1.24 firmware) cc bec wired directly to servo team brood 35t motors 14 tooth pinions front and rear heres my problems 1) my rear tires are turning slower than my front tires? 2) when i go to do a front dig it my rear tires dont lock up all the way. but everything works ok when i do rear dig. 3) when i turn my radio on is asks if i want to run beta mode and i accept cause iam running DSM1 RX. but on the main screen it says beta demo. is that something i should worry about? heres my settings on the radio throttle (channel 2) front esc Trim - 0 Dual Rate - 60 Throttle expo - 0 Brake expo - 0 Sub trim - 0 Brake End point - 190 Throttle end point - 190 dr mode - both reverse - off type - digital throttle (channel 3) rear esc Trim - 0 Dual Rate - 60 low end point - 125 high end point - 190 Dr mode - both reverse- -off type - digital mode - throttle/brake steps - 2 soft keys grip soft key ch3 dual rate setting value wheel soft key thr trim adjusting value t1 soft key steering trim t2 soft key nothing t3 soft key nothing t4 soft key thr dual rate setting value please help Thnaks for your time guys and gals CrawlHer Last edited by CrawlHer; 06-09-2011 at 08:22 PM. |
06-09-2011, 09:07 PM | #2 | |
06-09-2011, 09:15 PM | #3 |
Thanks for the help Jeremy 1) running 14t pinion front and rear, mesh is good, throttle and steering trims are on zero 2) should i set my radio up like yours and see what happens? everything except channel 4 3) so its nothing i should worry about then right? thanks for the help man. hopefully this help |
06-09-2011, 09:17 PM | #4 |
Well, I would use mine as a guide, but set up the soft keys how you like. Also, pay close attention to the "DR Mode" and "type" selections....
06-09-2011, 09:23 PM | #5 |
I wanna be Dave Join Date: Oct 2006 Location: Milwaukie OR
I think you're having issues with your expos only being at 60. Or you might be losing some throttle. Duplicate Jeremy's and then re-calibrate your ESC's. I am running a react with micro pros(or at least have in the past) and never had issues. I would be happy to send you a profile if you continue to have issues.
06-09-2011, 09:33 PM | #6 |
ok guys i just duplicated jeremys profile and now the digs seem to work but i cant figure out why my rear tires are going slower than my fronts. thanks for the quick replies and all the help |
06-09-2011, 09:38 PM | #7 |
Are you getting Green LEDs with forward throttle on both ESCs? Do they both shine solid instead of blinking?
06-09-2011, 09:39 PM | #8 |
RCC Addict Join Date: Jan 2008 Location: Apple Valley,CA
What the reason for the rear endpoints being different? throttle (channel 3) rear esc Trim - 0 Dual Rate - 60 low end point - 125 high end point - 190 I have a feeling that will make your rear esc only see full throttle (or brake) as appx 75%-80% of what your front esc is set at since it is set to 190. I would put all 4 of those values to 100 (or 190 in your case) and recalibrate real quick. Front esc epas and rear esc epas I mean. Last edited by Illeagle; 06-09-2011 at 09:45 PM. |
06-09-2011, 09:41 PM | #9 |
Rock Crawler Join Date: Feb 2006 Location: Where the foams are always wet
06-09-2011, 09:41 PM | #10 |
just tried recalibrating the esc's and no luck. the rear tires still spin slower than the front.
06-09-2011, 09:43 PM | #11 |
06-09-2011, 09:49 PM | #12 |
06-09-2011, 09:51 PM | #13 |
What are the settings on your ESCs? And I will ask again.....are the ESCs programmed EXACTLY the same??
06-09-2011, 10:05 PM | #14 |
If all the programming and mixing is "correct", it may be small differences in the motors that are causing the slight speed difference. Do you have a tach? It would be easiest to just apply a constant voltage to each motor and set the timing to get the speeds even. |
06-09-2011, 10:07 PM | #15 |
06-09-2011, 10:21 PM | #16 |
Quarry Creeper Join Date: Nov 2010 Location: Canada
I am running a React and Mamba Micro Pros. Matched 40T broods. My rear motor runs a bit faster than the front aswell. I want it setup like this for a front overdrive effect to improve turning and lessen the rear driving under the front on verticals. To get them to run even I just adjust my dual rate on the 3rd channel. about 80% runs them evenly. |
06-09-2011, 10:32 PM | #17 |
i think i have found my problem. all of my esc setting are the same except for the throttle curves. i never mess with them and or look in there so it never dawned on me to check. till Jeremy said to make sure everything was the same. Thank you very much Jeremy and every one for all the help. now my rear tires start just a tad sooner than the front. |
06-09-2011, 10:34 PM | #18 | ||
this is excalty what i just did. i toned my 3rd channel dual rate down to around 90%. and it works great. Quote:
your right my front esc throttle curve was WAAAAYYYYYY different than my rear. i have no clue how it got like that but it did. i matched it to my rear esc throttle curve and presto. now they run very close to insync. Last edited by CrawlHer; 06-09-2011 at 10:38 PM. | ||
06-10-2011, 06:48 AM | #19 | |
Glad you got it worked out. | |
06-10-2011, 09:50 AM | #20 |
thanks again jeremy thats exactly what i did. now i have those files saved just incase it happenes again. CrawlHer |
