06-11-2011, 08:26 PM | #1 |
Rock Stacker Join Date: Sep 2010 Location: Cedar Rapids
| Dual FXR no go
So I went to dual ESC controlled by a 4pks, did Harley's setup program. I can go through set up the ESC's and they recognize the inputs from the radio then when all said an done I get nothing. Like they arent seeing any signal from the rx. I have steering but no throttle. Any of you all had or seen this problem? Any input or comments would be great. Thanks in advance |
06-11-2011, 08:31 PM | #2 |
Are you sure your trim is not at zero, both dig switches are on or that your bias on each is set down to zero?
06-11-2011, 08:47 PM | #3 |
Yep, turn both mix functions on. Trim can not be set at zero? Where is the bias located at on the menu? I went through the set up with Harley on his YouTube vid and I don't remember him talking about any bias setting.
06-11-2011, 08:53 PM | #4 |
It would be one of the switches that you set to move in 5% (or similar) increments....
06-11-2011, 09:19 PM | #5 |
Rock Crawler Join Date: Oct 2009 Location: Michigan
Id go through the video again you may have over looked something. I set both of my FXR's up with a Tekin Hotwire before I even plugged it into the rx so I was sure they both had the same settings.
06-11-2011, 09:19 PM | #6 |
Okie dokie. Yeah, no they are both set to 100%. I'm sure its something simple and it's right there but.... |
