![]() | #2141 |
Rock Crawler Join Date: Apr 2007 Location: presKit
OK I updated to firmware 0.6.1 and everything works but the rear steer ....... CH4-*Independent*rear steer on d/r (Non-mom ???) below is my issue, Long click REV, got that scroll to d, enter got that scroll to CH4, enter NO CHANNEL 4 Scroll to BNL, enter XXXXXXXXX scroll to 100, Long enter XXXXXXX How do i get channel 4 to show??? |
![]() | #2142 |
Are you 100% sure 6.1 loaded into the radio? because it should show you all the channels available after d , maybe losikid will chime in
![]() | #2143 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
Austin..... whats up brotha??? So since ive been out of the loop for a while whats the DL on the GT3B these days??? Im still running V4.? in my radio i think....... catch me up and whats up with the 3C??? Last edited by JokersWild; 10-14-2012 at 10:32 PM. |
![]() | #2144 |
Pebble Pounder Join Date: Jun 2012 Location: Canada
I have my xr10 running with dual esc and a GT3b. If I let it sit the rear motor will give a little snap all by itself every minute or so. No real issue while driving or anything, just the odd glitch when idle. anyone else seen this with the GT3B or should I be blaming the ESC. (brand new sidewinder micro)
![]() | #2145 | |
| ![]() Quote:
I have the same set-up, no issues that I've seen. I'm assuming you calibrated both ESC's to the RX? Which dual ESC template are you running....the locked or momentary? Also, which firmware is in the TX? I have the 0.4.1 (?). | |
![]() | #2146 | |
Quarry Creeper ![]() Join Date: Feb 2011 Location: Las Vegas 89121
| ![]() Quote:
![]() | #2147 | |
| ![]() Quote:
I am not overly concerned about it. Especially now that others have seen it with out any major issue. I was going to calibrate the ESC's, but i tried following the directions, and I don't have a voltmeter. Last edited by spillproof; 10-15-2012 at 04:12 PM. | |
![]() | #2148 | |
| ![]() Quote:
This is what you need... http://www.castlecreations.com/suppo...s_ed_guide.pdf And... Castle Creations | FAQ: 1/10th Scale Products ![]() | |
![]() | #2149 |
Uh, I followed the calibration steps for the ESC, and now they stopped working... TX on full throttle plug in battery, ESC beep and show red. full reverse, they tone and show yellow neutral, get tone again, then try to use it, and no response.... |
![]() | #2150 |
So using a dead battery while calibrating will confuse you... lol stupid LVD...
![]() | #2151 |
![]() | #2152 |
Yeah working great now. I think it has more top end now to. Had to set my rx failsafe again, which was weird. Gonna let it sit, see if it glitches again.
![]() | #2153 | |
| ![]() Quote:
![]() | #2154 | |
| ![]() Quote:
GT3c is the new gt3b... | |
![]() | #2155 |
Newbie Join Date: Apr 2012 Location: San Diego
Ready to order... any idea on when you'll have stock?
![]() | #2156 |
Rock Crawler Join Date: May 2008 Location: At the corner of Bedlam and Squalor.
I'm wondering which is the appropriate version of the firmware to download, given my needs. I only need 3 channels, but would like stuff like proper expo, servo speed, low voltage adjustment and all the other glitch fixes. This is just going on my trail truck, so no need for 63 model memory, etc. Thanks. Jim |
![]() | #2157 |
0.6.1, there's no reason to have any other version
![]() | #2158 |
inactivity timer. enough said.
![]() | #2159 |
![]() | #2160 |
Good call. Thanks.
![]() LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
