![]() | #2201 |
![]() | #2202 |
Quarry Creeper Join Date: Jan 2012 Location: Bloomington
Yay!! ![]() |
![]() | #2203 |
Pretty much same as dual esc, except go to "4" in the e.point menu. And select 4WS instead of DIG as your function when assigning switches
![]() | #2204 | ||||
Quarry Creeper Join Date: Sep 2011 Location: Columbus, Ohio USA
| ![]() Quote:
![]() Quote:
I'm on fire now but I can't get my RC4wd winch to work yet ![]() ![]() I have this one... Bulldog 9300XT Scale Winch (RED) Quote:
Well it has the same problem on 3 rigs, it is most noticeable on my Wraith. It seems to start out not as bad then it gets worse as it gets hot or something. I admit at the track I found myself wrenching on the wheel, I'd notice when the plastic started creaking ![]() ![]() Oh and most importantly the new GT3 is fine so that rules out rx's If you find one let me know, and if you think it might be something else in the tx I'm listening... Thanks Speed | ||||
![]() | #2205 | ||
| ![]() Quote:
![]() Quote:
I can get one around thanksgiving time for you if i head back home(I left alot of parts radios and boxes of rc shat in the garage when i moved) | ||
![]() | #2206 | |
Archive is broke on my end sir Quote:
![]() | #2207 |
Your clicking on the first link in the second post of this thread? this link here, does not work for you? Index of /GT3B/GT3B-Firmware Does the winch work with another radio? |
![]() | #2208 | |
| ![]() Quote:
I'm clicking here, circled in red ![]() | |
![]() | #2209 |
1st page of this thread
![]() | #2210 |
The link in the product page for the hack kit works too... I can't change that side bar, it was built with my old website builder, which i changed from. So tis pretty much stuck like that till i get my new one finished |
![]() | #2211 | ||
| ![]() Quote:
![]() Back to the winch, no I have never seen it work right. Should it have worked with a stock GT3? Only way to reverse the winch is to swap polarity. | ||
![]() | #2212 |
Rock Crawler Join Date: Apr 2007 Location: presKit
![]() | #2213 |
![]() | #2214 |
Newbie Join Date: Oct 2012 Location: Green Lane
Ok I just got a GT3C.. I have the 3ch receiver.. I'm going to run dual esc's in my xr10, so I want dig, and esc mixing.. If I get a 6ch receiver, Where would my 2nd esc plug into.. I heard you can program each receiver channel so i can have proportional dig. If it matters, I will be using a bec..
![]() | #2215 | |
I wanna be Dave Join Date: Feb 2007 Location: South FL
| ![]() Quote:
![]() | #2216 |
Yeah it will work.. But I won't be able to have dig..
![]() | #2217 |
You still would have dig. Ch1 steering, ch2 esc1, ch3 esc2, batt is for bec, or run the bec to the servo only and have one esc power the rx. That's how I have my xr10 Sent from my iPad using Tapatalk |
![]() | #2218 | |
| ![]() Quote:
I'm running a hacked GT3B, 0.4.1 firmware and the "dual ESC, locked dig" template. | |
![]() | #2219 |
Pebble Pounder Join Date: Mar 2010 Location: Stillwater
I used my GT3C hacked controller a lot this weekend and it would randomly beep at me with nothing flashing or different showing up on the screen. It still worked fine but then it just started turning off, but the throttle would be stuck at where it was when it turned itself off. A quick push if the power button would reset thing and it would work fine again. Any ideas? Another bug I'm seeing is when running on my 4ws buggy the rear steer gets really lazy sometimes or will get stuck until I let off of the throttle. I'm running a HH BRXL, integy 55t motor and hi-tec 645mg servos. No BEC currently with this setup. This is also a random thing that usually happens when my Lipo is running at around half charge. I've got the same setup on my gt3b though without issue. These things started with the radio swap. |
![]() | #2220 |
BB, I would say to check the battery meter on the TX, I know the GT3B has a calibration for the low power alarm. This will require a meter. Also look at your on/off switch wiring. A number of earlier GT3C's would rip the wires off the switch. |
![]() LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 01:49 PM |
