![]() | #2221 | |
Pebble Pounder Join Date: Sep 2012 Location: Ljubljana, Slovenia
| ![]() Quote:
the turning off is the power button issue , this is from another forum so im not taking any credit ,all the credit goes to Billdelong , the original poster! I recently purchased the FS-GT3C radio and had a problem with the power switch failing after only my second day of racing or roughly 2 hours of combined use. If you are buying a new radio, I highly recommend removing the rubber grommet (top item in first pic below) which holds the switch wires in place as a preventative. 1) Pry the power switch off with a mini flat head screwdriver 2) Remove the 2 small phillips screws that hold the steering wheel in place 3) Remove the 3 medium phillips screws holding the steering assembly in place 4) Remove both of the 2.5mm hex screws holding the steering bracket 5) Pry off the power switch assembly(bottom piece in first photo) from the potentiometer with a small screw driver 6) Remove ball bearing from power switch assembly 7) Remove the rubber grommet ![]() ***repeat steps in reverse leaving as much slack as possible in the wiring also leaving the wires un-twisted as seen in the second photo ![]() ![]() | |
![]() | #2222 | |
| ![]() Quote:
That doesn't work, the switch will still fail...It just needs to be replaced with a toggle or another switch, someone posted something afew weeks ago how they did it, which was the same thing i've had in mind (just never got around to doing it)...i should have a guide up soon (and switches up on my site) FUN FACT: though, my prototype GT3C, still running 100% and has never had the power button issue...so i'm not sure whats completely causing the issues with the production versions as mine looks identical. | |
![]() | #2223 | |
| ![]() Quote:
The second issue, sounds like your servo is taking a shit or you need a bec | |
![]() | #2224 |
Rock Stacker Join Date: Jan 2012 Location: North Delta
Sorry, this has probably been asked somewhere in the last hundred pages. But I just picked up a used GT3B that has been hacked, but I don't have the wire to update the firmware. How can I tell what version I have so I can track down the correct programming info?
![]() | #2225 | |
Quarry Creeper Join Date: Nov 2009 Location: Central Arkansas
| ![]() Quote:
![]() | #2226 |
| ![]() If you press long enter after power up, the first screen should be firmware version, should display 3 digits
![]() | #2227 |
![]() | #2228 |
![]() | #2229 |
Sweet, just need to find a manual for it then, I have the dig working on the 3rd channel as a 3 way switch, Just need to figure out how to program it for the progressive steps. Looks like this thing will do me nicely.
![]() | #2230 |
![]() | #2231 | |
Quarry Creeper Join Date: Sep 2011 Location: Lexington
| ![]() Quote:
I'm getting the same error when I try to update my GT3B. And when I plug it into my GT3C the radio just continually beeps. Also gives the same error though when I try to program. On a side note the only reason I was trying to update was to solve this issue: (currently running 4.1) I'm using a 6ch rx setup with a winch controlled by the ch3 trim on channel four with 4ws. I'm trying to use either channel 5 or 6 to switch my lights on and off. Can I do this without updating the firmware? | |
![]() | #2232 |
0.4.1 will do that if you have the 6ch version As for your problem, make sure you plug radio into programmer programmer into computer Open STVP Open Firmware Press Program --> Current tab In that specific order |
![]() | #2233 | |
| ![]() Quote:
![]() What do I set the channel at so it will operate like an on/off switch? (On the 3B) Scale beer cans, now that's the schlitz! Last edited by Duxx; 11-01-2012 at 05:39 PM. | |
![]() | #2234 |
Which switch do you want to act as on/off? (Lots aways todo this, so i have a string of questions to ask before i can say how todo it) |
![]() | #2235 | |
| ![]() Quote:
The 3C is flashed to 6.1 but I'm struggling mightily with the key mapping for it! Scale beer cans, now that's the schlitz! | |
![]() | #2236 | |
| ![]() Quote:
![]() | #2237 | |
| ![]() Quote:
I want it to turn the lights on when I push it and turn them off when I push it again....... Scale beer cans, now that's the schlitz! | |
![]() | #2238 |
Long click REV, scroll to c, enter scroll to ch3, enter scroll to swi long enter |
![]() | #2239 | |
| ![]() Quote:
Here's what I'm after: I like the ch3 trim for the front winch. I like the ability to change from front/rear and 4ws. No need for crab. And I'd like ch3 button to turn lights on/off. Thanks for the help, again.... Scale beer cans, now that's the schlitz! | |
![]() | #2240 | |
| ![]() Quote:
![]() LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 01:49 PM |
