![]() | #2301 |
I wanna be Dave ![]() Join Date: Jul 2009 Location: Rancho Relaxo. California. USA. Earth.
Went through almost the same deal on a 3c with 0.6.1. Only thing changed in my setup was going from a 3b to 3c. Traced it to a hobbyking rx. Switched it out to a Flysky badged rx, binded and problem went away. Only difference is I'm using a small esc to power the winch but it was acting the same way described. |
![]() | #2302 | |
| ![]() Quote:
![]() | #2303 |
Very weird. I was under the impression that hk and flysky rx's are the same stuff. Chalking it up to faulty rx. Just thought it was worth mentioning to try another rx. |
![]() | #2304 |
![]() | #2305 | ||
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
| ![]() Quote:
![]() | #2306 |
I wanna be Dave ![]() Join Date: Apr 2010 Location: Oakridge
Hope someone can help me with a problem I'm having with my gt3c with 6.1. When I pull the trigger the speed control does not engage until I have used about 1/3 of the trigger. I'm sure it is something simple: I have tried adjusting the trim, calibrated the radio several times, setup esc to rx with different epa-trim settings. I want the esc to engage at the beginning of the throttle. Thanks for your help!!!
![]() | #2307 | |
| ![]() Quote:
2-You only really need to bind the TX & RX 3-To calibrate the ESC to the RX: -Throttle trims to "0" (including subtrims) -Throttle EPA's to "100%" -Calibrate the ESC (how depends on the ESC) Also check to see if you have "EXPO" set in the TX on the throttle channel. What ESC? If a Castle ESC, do yoy have throttle curves set? | |
![]() | #2308 |
![]() | #2309 |
![]() | #2310 |
| ![]() The delay sounds like the winch controller in use (what is it?)
![]() | #2311 |
Thanks Charlie that fixed it!!!!
![]() | #2312 |
![]() | #2313 |
![]() | #2314 |
| ![]() No, I had the trim set at 50%. Changed to 0 and reset tx to esc and restarted. Oh by the way the esc is Tekin rs. my wife and I were back in New England for three weeks in first part of Oct. We photograghed fall colors and visited with family. Did eight states and logged 2200 miles on rental car. I thought about contacting you but couldn't put my camera down long enough to do so. Made it home the week before Sandy!!! |
![]() | #2315 | |
Newbie Join Date: Nov 2012 Location: SoCal
Can this be used with 0.6.1 as well? Quote:
![]() | #2316 |
![]() | #2317 |
What's the best way to do 4ws? Any templates for it?
![]() | #2318 |
Hi losikid. Sorry for not introducing myself. I got the gt3c and got your hack kit for it because it can do 4ws mix and such though im not sure what the full potential is. I wanted to do 4ws like this. Let me know if its possible. Channel 3 button - switch from crab, normal, opposing Th trim - left would turn rear wheel to predetermine left and right trim button would turn it right |
![]() | #2319 |
Rock Stacker Join Date: Mar 2007 Location: Australia
Hi all just got my hacked gt3c Having trouble setting up my winch to work off 3rd channel can someone help me with a template? First time I've used a radio like this I'm lost. Thanks in advance Scott |
![]() | #2320 |
You need to assign a switch to control ch3 These may help http://www.overkillrc.com/GT3X-Firmw...lp%20cards.pdf And heres the manual http://www.overkillrc.com/GT3X-Firmw...NUAL-0.6.1.txt |
![]() LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
