01-29-2013, 12:51 AM | #2521 |
Pebble Pounder Join Date: Nov 2012 Location: Australia
| Re: GT3B Hack Question and Answer Thread
Sorry losikid, I was planing to get one from you. But the right deal popped up here and I jumped on it. So far your posts in this thread have been invaluable in setting up my dual esc's. But I was thinking. Is it possible to set the ch 3 button to dig the rear axle only, then set the ch 3 trim button to do proportional dig, then set up the D/R trim button to control the rear steer servo? Once again thanks so much for doing what you have down with the gt3b Cheers David |
01-29-2013, 03:08 AM | #2522 |
RCC Addict Join Date: Dec 2011 Location: Australia Queensland!
I'm intrigued is this possible with the hacked gt3b? If so I may have to order one as I'm after the same thing, to run rear steer and dig.
01-29-2013, 03:40 AM | #2523 |
Quarry Creeper Join Date: Mar 2012 Location: New Jersey, USA
| Re: GT3B Hack Question and Answer Thread |
01-29-2013, 03:50 AM | #2524 |
Just can't figure out how to set it up
01-29-2013, 04:42 AM | #2525 |
01-29-2013, 05:09 AM | #2526 |
I have found the manual for the 0.4.1 firmware but it's all a foreign to me, I'm a hands on mechanic kind guy not a software guy
01-29-2013, 06:43 AM | #2527 |
Newbie Join Date: Jan 2013 Location: Harford County
Im going to be needing ur guys help here shortly once I get my gt3b
01-29-2013, 10:10 AM | #2528 |
Rock Stacker Join Date: Dec 2006 Location: charleston
Is it possible to set the ch 3 button to dig the rear axle only, then set the ch 3 trim button to do proportional dig I would like to see this question answered sounds pretty cool and would like to have mine set up this way Last edited by tbacon38; 01-29-2013 at 10:19 AM. |
01-29-2013, 12:55 PM | #2529 |
| Re: GT3B Hack Question and Answer Thread This thread is 127 pages long, and i've answered your question countless amount of times, so i'm sure if you read, you'll find an answer. I'll give you a hint though, post #2
01-29-2013, 05:56 PM | #2530 |
I've read post # 2, am I missing something? I can't seem to find what I'm looking for. Is this even possible on 0.4.1? Or am I barking up the wrong tree? |
01-29-2013, 09:29 PM | #2531 |
01-29-2013, 10:46 PM | #2532 |
Quarry Creeper Join Date: Apr 2011 Location: bay area
Can no one help me with this Sent from my DROIDX using Tapatalk 2 |
01-29-2013, 10:57 PM | #2533 |
01-29-2013, 11:01 PM | #2534 |
| Re: GT3B Hack Question and Answer Thread Ok, so atleast I know it is possible and I'm not going crazy for no reason, I will try again to find the right setup tonight when I'm home from work. So to clarify, this is what I'm aiming for: front steer on ch1, 1st esc on ch2, 2nd esc on ch3, rear steer on a 4th channel. Momentary dig for rear axle set to ch3 button, fr and rr proportional dig on ch3 trim switch and rear steer on d/r trim switch. Cheers David. |
01-29-2013, 11:08 PM | #2535 | |
| Re: GT3B Hack Question and Answer Thread Quote:
01-29-2013, 11:08 PM | #2536 |
Quarry Creeper Join Date: Mar 2012 Location: Roseburg
I forget, does 0.4.1 allow you to select number of channels like 0.6.1? if so, so good so far. Sounds like you need 6 channels if Im counting correctly. You have the proper number of channels on the receiver? I know it can mix the ESCs, manual will tell how once you wrap your head around it. I know itll do dig, has a menu to set up that, never used it but have scrolled past it. There are also setting for 4ws, under the 4wd menu. I have not used most of these features but know they exist. For me, the trick was to make the manual understandable for me. I know your frustration, took me for ever to even figure out how to make my Ch3 a 3 position switch. |
01-29-2013, 11:10 PM | #2537 | |
01-29-2013, 11:29 PM | #2538 |
01-29-2013, 11:31 PM | #2539 |
Im trying to set up some lights, would I be able to just turn them on and off with the 3ch button on the handle. I do have it hacked and running the 6.1 Sent from my DROIDX using Tapatalk 2 |
01-29-2013, 11:35 PM | #2540 |
Use a servo board and connect the lights to where the servo motor would go. Thats the only way I can think of off the top of my head. If you do a quick google you should be able to find if you should replace the POT and what resistor values to do so. |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
