01-29-2013, 11:40 PM | #2541 |
Pebble Pounder Join Date: Nov 2012 Location: Australia
| Re: GT3B Hack Question and Answer Thread |
01-30-2013, 01:34 AM | #2542 |
Ok , well I asked the guy I bought the tx from and he tells me that it is installed with the 3ch 4.1 fw so I guess I can't run duel esc's and duels steer at the moment, oh well still digging the duel esc setup (pun intended) guess I might have to reflash it at a later date.
01-30-2013, 10:49 AM | #2543 |
Quarry Creeper Join Date: Mar 2012 Location: Roseburg
You can run dual of both if you put a Y harness on but you won't get the overdrive/under drive and 1:1 on the servos with no crabbing and such.
01-31-2013, 05:46 AM | #2544 |
Ok, I got my second esc in (an axial ae-2) and the duel esc mixing works a treat. But I've noticed that I have to dial in 20% rear trim on ch2 (front axle) to find a neutral point. Could this be because at the moment I have miss matched esc's (my other one is the stock esc from a redcat rs10)? I do plan on getting another ae-2 but finances atm stopped me from buying 2.
01-31-2013, 10:02 AM | #2545 |
I'd say that's the issue, Miss matched ESCs.
01-31-2013, 02:34 PM | #2546 |
did you calibrate the esc's at the same time at 0% mix?
01-31-2013, 06:53 PM | #2547 |
I did them individually, should I do them together?
01-31-2013, 08:08 PM | #2548 | |
| Re: GT3B Hack Question and Answer Thread Quote:
You can calibrate either way, just make sure: Throttle trims to "0" Throttle EPA's to "100%" Throttle mix to "0" I usually calibrate both my ESC's at once, but either way works. | |
02-02-2013, 08:33 AM | #2549 |
Rock Crawler Join Date: Nov 2012 Location: Charlotte
Hey guys, what's the best way to open the steering wheel assembly of the GT3C? I want to snip those guides, but I dont know how to open it up without breaking the assembly. Thanks! |
02-02-2013, 08:55 AM | #2550 |
There's two screws connecting the assembly to the main housing of the transmitter. And three screws behind the wheel to open up the assembly itself, look through the wheel. For one, you may have to turn the wheel slightly.
02-02-2013, 09:11 AM | #2551 |
Thanks bud!
02-02-2013, 09:48 AM | #2552 |
And now the power button is good to go. Woot!
02-02-2013, 11:16 AM | #2553 |
Np |
02-02-2013, 04:03 PM | #2554 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
hey dude. my gt3b is modded, and works well, but has recently been saying low voltage all the time. like fown to 7.5v on a 3s lipo. is this normal? when plug tha battery into charge it read full charge. usually these batteries last months without needing a charge in the TX. now it last about 10 minutes. |
02-02-2013, 04:03 PM | #2555 |
02-02-2013, 04:55 PM | #2556 |
Quarry Creeper Join Date: Apr 2011 Location: bay area
Sounds like you might have a dead cell I'd try a different battery Sent from my DROIDX using Tapatalk 2 |
02-02-2013, 05:51 PM | #2557 |
tried a diff battery and its fine; me dummy |
02-04-2013, 07:58 PM | #2558 |
Quarry Creeper Join Date: Jan 2012 Location: Bloomington
I wish there was a way to organize this thread somehow. It seems like a lot of the questions asked have already been asked a hundred times. I realize some are specific to people, but there are so many repeats! There's no way somebody would read through 130 pages to find an answer. The search button is a tool I wish people would use more, but even a simple search yields a LOT of results. I have no solution for this problem, just a statement. One can not even begin to organize this Monstrous thread.
02-04-2013, 08:04 PM | #2559 |
Imo its really up to the person who requires the information to seek it out. losikid and other knowledgeable users are kind enough to be helpful again and again and again and again. If it takes an evening to skim/search this morbidly obese, monstrosity of a helpful thread then so be it. Things taste better when it takes awhile to make it, instant gratification isn't all its cracked up to be.
02-07-2013, 06:30 AM | #2560 |
Ok, I thought I had this programming figured out, I am trying to set a semi( knight hauler) on this radio, I want the 3rd channel to do 100-0-100 for the three speed and the 4th channel on the d/r button to do two position for the cargo lock/unlock function, I cant get it right |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
