04-12-2013, 07:57 PM | #2721 |
| Re: GT3B Hack Question and Answer Thread |
04-12-2013, 07:59 PM | #2722 |
Hey LosiKid...on a GT3C, is the VR mod still suggested, or "just nice"? I just got in 2 GT3C's, want to cover bases before I put them in use. Thanks. |
04-13-2013, 06:43 PM | #2723 |
Rock Crawler Join Date: May 2010 Location: Bedford Ky
Hey this is all I've got on the screen u can scroll thru voltage something that says left forward and a big off sign a right back with a off sign and model number Sent from my iPhone in the shop |
04-13-2013, 11:59 PM | #2724 | |
Newbie Join Date: Jan 2012 Location: Queensland Australia
| Re: GT3B Hack Question and Answer Thread Quote:
hi try this to get your F/W version turn on unit press and hold scroll wheel will put into global setting model and name will be flashing at top of screen under it will be F 061 for 0.6.1 F/W and so on press back to exit | |
04-14-2013, 03:03 AM | #2725 |
Rock Crawler Join Date: Aug 2012 Location: Koloa boy 808 2 DA 206
cant wait to get this radio im trading some wheels for one this week any advice on lipo mod do you have to install the voltage regulator to run a lipo battery in it and does it have to be a 3s
04-14-2013, 03:20 AM | #2726 |
| Re: GT3B Hack Question and Answer Thread hi for the benefits the VR mod has, it is worth doing then you can run 2 or 3 cell lipos. must have mod for 3 cell. i run a 3 cell lipo and use every day recharge maybe every 3/4 weeks , sometimes longer .
04-14-2013, 04:53 PM | #2727 |
Finally figured out my firmware version looks like its 6.1 thanks to all who have helped After I found the firmware I tore it apart to check for the vr mod and found the factory vr intact looks like I'm fixing to do some soldering once I order the new vr Sent from my iPhone in the shop |
04-14-2013, 05:57 PM | #2728 |
04-14-2013, 06:27 PM | #2729 | |
Austin, thanks for the reply. I showed a number of peeps the hacked GT3B vs. the unhacked GT3C today at a GSRCRC/EPARCC comp today. I hope to have time to convert my GT3B to the newer firmware soon. I even had a few drivers drive my rig (sorta basic XR-10) with the hacked GT3B today. I believe they came away with "It's good" replies. | |
04-14-2013, 07:27 PM | #2730 | |
04-14-2013, 07:29 PM | #2731 |
Yeah I'll start figuring out the programming once I get it wrapped with the custom skins I had made for it Sent from my iPhone in the shop |
04-14-2013, 08:27 PM | #2732 |
Rock Crawler Join Date: Apr 2011 Location: Sonoma County
3Racing Winch controller question: using hacked 0.61 + 6ch flysky Tx I set the 3 position switch to mom and when I use it I see the -100 and 100 flash on the screen when it is held. I only get the winch to go in one direction. One does nothing. I can push the button on the winch controller and it will go in both directions. Also, I can plug the winch into ch1 and it will go both directions when I turn the steering wheel... HeyOk helped me earlier today and is at a loss. So Losikid, any ideas? Thanks! |
04-14-2013, 08:57 PM | #2733 |
check your epa
04-14-2013, 10:05 PM | #2734 |
OMG I'm dumb. That worked. How is a hack's tech support better than forune 500 companies? Thanks! |
04-15-2013, 04:01 PM | #2735 |
does this radio need a voltage regulator to run the 3s lipo
04-15-2013, 04:05 PM | #2736 |
| Re: GT3B Hack Question and Answer Thread is there a thread on this mod is it the black voltage regulator in the control that needs to be replace the guy giving it to me has a 3 s lipo hooked up but did not do anything else will it damage the radio/ WHERE can i get this mod for the 3s lipo swap thanks
04-15-2013, 04:10 PM | #2737 |
04-15-2013, 04:13 PM | #2738 | |
04-16-2013, 02:31 AM | #2739 |
thanks
04-16-2013, 04:31 PM | #2740 |
| Re: GT3B Hack Question and Answer Thread im not plan on charging it through the remote i was going to take out the lipo and charge it separtely so I dont need the voltage regulator then? just connect the lipo and im good?
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
