05-08-2013, 02:45 PM | #2801 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
| Re: GT3B Hack Question and Answer Thread
would the hack kit fix that?
05-08-2013, 02:53 PM | #2802 |
No. Try getting a couple remote switches and wiring them in reverse to your esc power switches. Although you'd have to run some type of bec to constantly power the rx's. Tap a button and one goes off, the other goes on. Or much easier/cheaper... Use traditional power switches and just walk over and flick it. |
05-09-2013, 06:39 PM | #2803 |
Rock Stacker Join Date: Aug 2012 Location: Roan Mountain
Hi I just hacked my GT3b and can't get Ch2 to work. My ESC won't calibrate with the radio. I have tried two different firmware and they both done the same thing. Please help.
05-10-2013, 02:15 PM | #2804 |
Pebble Pounder Join Date: Apr 2008 Location: Appalachia
Can a momentary mix be activated with the 3rd channel button? Say like 4WS while pushed and only front when not?
05-10-2013, 03:49 PM | #2805 |
| Re: GT3B Hack Question and Answer Thread |
05-10-2013, 09:19 PM | #2806 |
Newbie Join Date: Apr 2013 Location: Ocala
Need Help! Trying to hack my remote and I keep getting errors like "Error checking device! Check the configuration or the device". What does this mean, what am I doing wrong.
05-12-2013, 10:09 AM | #2807 |
Quarry Creeper Join Date: May 2010 Location: scotland
does anyone in the united kingdom offer there services to hack this controller
05-12-2013, 02:13 PM | #2808 |
Newbie Join Date: Apr 2013 Location: Peoria
I've searched til my eyes are bleeding. If I missed I'm sorry. My granddaughter & I would like to be able to turn 4WS on & off with the D/R switch or the Ch3 trim switch. Can someone post a template for this? P.S. I am using Ch 3 for turning lights off & on. No dual ESCs; No Dig involved here. Thanks guys. The rear servo in in channel 5. I'm confused at to setting these up as switches, etc. Thanks guys this is SOOOOO fun. we're having a BLAST! RKP |
05-12-2013, 02:55 PM | #2809 |
05-12-2013, 05:02 PM | #2810 | |
Rock Crawler Join Date: Oct 2012 Location: Casper
| Re: GT3B Hack Question and Answer Thread Quote:
E. Point; long Enter 4; Enter 5; long Enter End Rev; long Enter 3; Enter 4WS; Enter BEN; Enter 100v; long Enter Rev; long Enter C; Enter 4WS; Enter MO0,RE0,PV0,4WSv; long Enter End End I think... had a cpl and I've slept since I've tried this. Let me know how it goes. Last edited by KJ10; 05-12-2013 at 05:07 PM. | |
05-12-2013, 06:56 PM | #2811 |
THAT'S IT!!! Thanks KJ10! You're the best! Still tryn to get my head around all this programming. RKP |
05-12-2013, 07:58 PM | #2812 |
NP! I had to help. I got the nickname of 'Captain Ron' from Rich Wyatt when I took his class. Totally non-rc but, still....
05-12-2013, 08:15 PM | #2813 | |
Newbie Join Date: Mar 2013 Location: middle
[QUOTE=Charlie-III;4311075] Quote:
05-15-2013, 02:30 AM | #2814 |
Newbie Join Date: Apr 2013 Location: Sweden
I have a big issue with GT3B and hopefully someone know what to do (Have googled my issue without any luck) I have a MOA (Berg) I use 2 * Hobbywing Esc. When i connect the escs to the receiver and calibrates them, the motor connected to ch 2 goes forward automaticly. as if i have to high value on trottle trim, if i lower it the motor goes down in rpm, but not to zero. If i brake the motor stops and goes into reverse. The steering works great. This issue i have had also on a Novak rooster esc. Anyone that can help me? I shall also add that the TX/RX is brand new and the TX is original (Will hack it in the future) |
05-15-2013, 07:41 PM | #2815 | |
Regardless, when you calibrate ESC's, you need to: -Set throttle EPA's to 100% -Set throttle trims (and subtrims) to "0" -Futaba radios need the throttle channels set to "reverse" -Then calibrate the ESC's It helps to have the same ESC's running the same firmware in a dual ESC set-up. PS, if the stock GT3B does not do dual ESC mixing, choices are: -Hack it -Contact LosiKid for a WantAmix -Contact HeyOK for his dual ESC controller Hacking is the cheapest route since you already have the radio. Last edited by Charlie-III; 05-18-2013 at 06:17 AM. Reason: fix typo | |
05-17-2013, 10:51 AM | #2816 |
Moderator Join Date: Jan 2004 Location: chicago
i just got another hacked gt3b (thank you) and was wondering if i can save and transfer the settings from my old one to the new one? my intention is to use it as a backup for my comp rigs in case the primary one gives the ghost. |
05-17-2013, 11:34 AM | #2817 | |
If i remember correctly, plug in your current controller, click read --> all tabs Then unplug that radio and plug in the new one then press program --> all tabs You may have to save the data you read, close out of stvp, and then open it up....but this may be tricky i can't remember, its been along time since i've saved/transferred settings. | |
05-17-2013, 11:47 AM | #2818 | |
thanks, i'll look into it. i got kinda lost last time i updated the firmware but i managed to figure it out. if thats too tricky for my thick head to figure out i can always do it manually. i only have about 3 or 4 rigs i want to have backed up anyway. will it keep the binds? Quote:
05-17-2013, 12:31 PM | #2819 | |
05-17-2013, 09:43 PM | #2820 |
I has someone ask about the wobble so OverkillRC presents the GT3B wobble |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
