05-20-2013, 07:14 AM | #2821 |
Rock Crawler Join Date: Jan 2013 Location: Middleburg Florida
| Re: GT3B Hack Question and Answer Thread
I'm sure this is in here somewhere but... I need a few more RX's. I have read they must be V2 type. Will these rx's bind up and work with my hacked gt3b? Hobby King GT-2 2.4Ghz Receiver 3Ch Hobby King 2.4Ghz Receiver 6Ch V2 I'm not seeing an 8ch version of this. But I do see this Turnigy 9X 2.4GHz 8Ch Receiver (V2) So will these all work or do I need to find something else? |
05-20-2013, 12:34 PM | #2822 |
Yep those will work....hobbypartz.com also sales them Also, first page second post of this thread has answers to your question... |
05-21-2013, 02:15 PM | #2823 |
Quarry Creeper Join Date: Oct 2012 Location: Sweden
Hi! Seems like something happened to your website, can´t access firmware archive and the link in "install instructions" to sttoolset.exe doen´t work either. Now it´s working again! Last edited by BliB; 05-21-2013 at 02:20 PM. |
05-21-2013, 06:39 PM | #2824 |
Pebble Pounder Join Date: Oct 2012 Location: Auburn CA
DID I FRY MY RADIO? So it worked fine before i flashed it now it wont turn on. (from the install instructions...These arrows need to be on the SB1 side on your programmer, and towards the BND button on the gt3b side...it’s also the black wire.) I fallowed all the steps. I think I know how to solder. I put the arrows where they are supposed to go on the harness when i flashed it. STVP said "error. cannot communicate with the device ! check the SWIM cable connection and check all the needed pin connectors on the SWIM connector" I checked the harness and pins and noticed that on one end of the harness the arrow points to the green wire all the way to one side. On the other end the arrow points to the red wire on the complete opposite side. HMM i thought. Tried disconnection and re connecting all wires, made sure remote worked, and restarted computer. Still nothing. Same error msg. So I turned the connector over on the remote side. Success or so I thought. It gave me all the good indicators at the bottom msg area. And even said it was successful but now the radio wont turn on. Any Thoughts? |
05-21-2013, 09:15 PM | #2825 |
A.) You're using an OLD install manual....I should just delete that file to avoid this.... B.) You didn't open the firmware before you pressed program....do what you did again but make sure to open the firmware file when you're in stvp |
05-22-2013, 01:52 AM | #2826 |
Hi I hacked my radio last night with 0.6.1 firmware, it seems like mixing is on, with my current dig switch i need the third channel to be working as just on/off. i can hear the relay switching when i start to drive forward, thats why i belive there is some kind of mixing activated. Was looking at the template to assign DIG mix to channel 3 Scroll to E.point, LONG enter Scroll to d, my radio shows d OFF Is it me thinking wrong as usual? Managed to figure this out, the 3ch button was off, choosing c and assign it to ch3 made it work as i wanted it to =) Last edited by BliB; 05-22-2013 at 03:42 AM. |
05-22-2013, 04:48 AM | #2827 |
| Re: GT3B Hack Question and Answer Thread |
05-22-2013, 08:43 PM | #2828 | |
| Re: GT3B Hack Question and Answer Thread Quote:
Index of /GT3B but people find the old links when searching and don't realize their old links. | |
05-23-2013, 12:43 PM | #2829 |
Newbie Join Date: Apr 2013 Location: Sweden
Hi! I have a issue wich i have been looking at, did not find the answer when the radio was unhacked and the same problem is still there now when it is hacked (V0.6.1) MOA Dual esc, brushless with sensor Front engine goes forward, Back engine goes backward. When i try to reverse the back engine it goes to full trottle reverse. I have tryed adjusting EPA but no luck. What is this problem? Last edited by ddr; 05-23-2013 at 12:59 PM. |
05-23-2013, 01:00 PM | #2830 |
How are you reversing the rear motor?
05-23-2013, 01:05 PM | #2831 |
05-23-2013, 01:27 PM | #2832 |
Then it should work fine....make sure to calibrate your esc's
05-23-2013, 01:36 PM | #2833 |
| Re: GT3B Hack Question and Answer Thread Have done it 2 ways. Caibrated it in Ch2 and then move the cable to ch3. And now, with the tx hacked in ch3. But still same problem. If i put it in reverse on channel3 the engine goes backwards. And if i try to go to the EPA the engine goes the same direction but much faster. |
05-23-2013, 01:39 PM | #2834 |
You have to setup Dual ESC mixing in the controller....turn DIG mix on, and setup your switches. Sounds like your mix isn't turned on |
05-23-2013, 01:53 PM | #2835 | |
I followed this one but the menu tree isnt the same: Ch3 trim-Momentary 3 postion dig D/R-Bias with 20% step rate Turn radio on press enter scroll till E. Points highlighted Press and hold enter for 1.5 seconds E. point should now be blinking scroll so "d" is blinking (far left) press enter scroll till 3 is blinking press enter make sure 0 is blinking, if not scroll so it is Press and hold enter for 1 second Scroll so REV is highlighted Press and hold enter for 1.5 seconds Rev should now be blinking Scroll so 3 is blinking press enter Scroll so DIG is blinking press enter scroll to MOM (Here is where it fails i get only MO) press enter Scroll so NOR is blinking (Here i get "RE 0 or 1") press enter scroll so PRV is blinking (Here i get "PV 0 or 1") press enter scroll so d is blinking press enter scroll to DIG press enter scroll so RES is blinking (RES is not an option) press enter scroll to 20 press enter scroll so NOR is blinking press enter scroll so N00 is Blinking press enter press and hold enter for 1.5 seconds press end Last edited by ddr; 05-23-2013 at 02:01 PM. | |
05-23-2013, 01:59 PM | #2836 |
05-23-2013, 02:55 PM | #2837 | |
| Re: GT3B Hack Question and Answer Thread Quote: When the ESC was beeping for forward i pushed reverse and vice versa. Now i got forward and reverse the right way. Now i go for the dig function :-) | |
05-24-2013, 08:00 AM | #2838 |
Now i got it to work, for a short period. When i am about to trim the EPA on ch3 the rear motor goes nuts and goes to full Speed. And after a while the dig wont work. Even if I am in normal mode the dig is random. Every 3-4 times when i push the trottle i get a delay in one of the axles. it is totaly random. Skickat från min GT-I9300 via Tapatalk 2 Last edited by ddr; 05-24-2013 at 08:47 AM. |
05-24-2013, 08:18 AM | #2839 |
05-24-2013, 08:20 AM | #2840 |
Hey, on another note. I've been looking for another GT3C and the usual sources seem to be out of them. Looks like street price is around $60-$65, but can't find one to buy. Anyone know where to look? LosiKID, do you have anymore? |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
