06-09-2013, 06:31 AM | #2881 |
Newbie Join Date: Aug 2011 Location: Surrey
| Re: GT3B Hack Question and Answer Thread
I'm still exspanding my knowledge on the hack firmware until the funds come in to make a purchase... Anyway, I love the fact that one can choose how many channels per model, however, say I set one up one model for 3 channels to match my rx. Then, later down the road, I decided to add some gizmo that requires a fourth channel. So I install a 6 channel rx, and then rebind the model. Now, is it possible to add another channel with out affecting the model's setups? |
06-09-2013, 07:52 AM | #2882 |
yes, just name that particular memory and add all the channels you need and settings to your liking for that particular new model, the rest will remain unaffected.
06-10-2013, 07:23 AM | #2883 |
Rock Crawler Join Date: Jan 2013 Location: Middleburg Florida
So 2 times in a row I have not been able to operate my hacked Flysky rc when running with a big group of others. It glitches out and is unusable. There are several others having the same issues with Spektrum radios as well. There are also 2-3 unhacked flysky radios being used. I did a google search and came to a thread on here saying that the cheapo chinese controllers aren't as finely tuned as better units. So would hacking and updating the firmware on them solve any issues regarding this? I have a hack kit and have the programs ready on my PC to do this.
06-10-2013, 11:55 AM | #2884 |
It doesn't surprise me that the spektrums glitch out...if you ask me, its because spektrum has the inferior technology. Generally, flyskys don't glitch out...i suggest trying fresh batteries in your remote, make sure the rx antenna isn't buried in a bundle of wires/metal/etc 2.4ghz needs a line of sight for the best signal strength, and make sure that the antenna wire inside of the radio is still soldered to the rf module. It is most likely you just have poor signal strength in a high interference environment. I do plan on offering a rf module upgrade kit here soon, it'll potentially decrease the latency by 50% (so twice as fast), possibility to use a lighter rx, and eliminate all the glitching issues. Only reason it's not a priority project is because the price tag will be $40-50 (That price includes 1 4ch rx) and its install is not as dummy resistant as the other hacks. |
06-10-2013, 12:44 PM | #2885 |
thanks for the info, the antennae isn't wrapped up in anything, not on any metal, the remote said 10.9V and I was having issues less then 5ft away. It would just lock up. The MMP was giving a rapid beeping signal that is faster then a normal signal when the TX is off. As soon as I got away from the group its perfect again. Both times it did this I was with the same group of people, same rapid beeps and everything. Also both times I ran it and it was perfect before everyone else fires up, then it just messes up. I have about 5 more RX's on order for this thing but I need it to run in a crowd. Would a different rx make a difference? |
06-10-2013, 03:31 PM | #2886 | |
| Re: GT3B Hack Question and Answer Thread Quote:
In our group (mostly GSRCRC & some with EPARCC), we run: Futaba 3PM-x & 4PL Multiple MT-4's Various other radios (I believe a few are Spektrum's). I have NEVER had an issue in my hacked GT3B or other radios. My son & I run either CC ESC's or FX-R's. Not sure where the issue is, curious as I now have 2 GT3C's as well, not in operation yet though. I doubt newer firmware will make a difference, it's more of a TX/RX & freq tolerance issue. | |
06-10-2013, 06:39 PM | #2887 |
Well it's interesting for sure. There are 4pl's and everything you can think of out here with this larger group as well. I run a ccbec and a CC MMP in both of my crawlers. Only my futaba 3pm-x runs fine with these guys though. So you don't think that hacking the unhacked radios would make a difference for anyone else experiencing the glitching? |
06-11-2013, 07:51 AM | #2888 |
Newbie Join Date: Apr 2011 Location: US
how long are orders taking?
06-11-2013, 09:50 AM | #2889 |
Pebble Pounder Join Date: Jan 2008 Location: New Bedford MA. USA
i'm getting a message can not communicate with board when i click the program tab any idea what i'm doing wrong.
06-11-2013, 12:39 PM | #2890 |
Rock Crawler Join Date: Feb 2012 Location: Michigan
| Re: GT3B Hack Question and Answer Thread |
06-11-2013, 01:12 PM | #2891 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
06-11-2013, 01:15 PM | #2892 | |
X2 never had any glitches and been around every radio. Maybe bad antenna lead? | |
06-11-2013, 02:45 PM | #2893 |
06-11-2013, 05:50 PM | #2894 | |
I've noticed that there are a variety of GT3Cs out there, green, orange, silver, and wonder if they all share the same internal electronics. If not, then, which is best suited for hacking? Also, way back on page one, or is it two, there is a post from Losikid with links to various sites that sell compatable receivers for the hacked flyskys. While researching things, I've noticed this: The GT3C's 2.5GHz system is listed as: AFHDS, and its 'code type' is listed as: GFSK. Now, the 6 channel flysky receiver's specs from Losikid's formentioned link, is listed as 'modulation: GFSK' and it's 'code type' as: PCM. Which is different from the transmitter. To add confusion to the matter, I found a 8 channel flysky receiver that has the same '2,4GHz system' and 'code type' as the tx, but is different from the 6 channel rx from Losikid's formentioned link, which also ommits a link to the 8 channel rx that I found, yet includes links to various sites for a number of receivers. So, I am wondering if both these receivers will work, and if not, then, what are the specs one needs to look for to find suitable receivers? | |
06-11-2013, 06:10 PM | #2895 | |
I've heard of very few cases of flyskys glitching out due to other flysky interference. I looked at one instance of it and the antenna on the radio had a broken solder joint (ie very low signal strength) | |
06-11-2013, 06:14 PM | #2896 | |
Also, the gt3b and gt3c uses the same rx's....all the rx's i posted will work. If you're concerned about one specific rx post a link and i (or someone) will confirm that it'll work. | |
06-11-2013, 08:43 PM | #2897 | |
No but a red and green hammer is a Christmas one....... Now that's different! | |
06-11-2013, 08:56 PM | #2898 |
lol
06-12-2013, 08:11 AM | #2899 |
06-14-2013, 05:51 AM | #2900 | |
Anyway, the receiver of concern is this one: FlySky 2.4G 8 CHANNEL RECEIVER ... will it work with a hacked flysky? | |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
