07-03-2013, 07:41 AM | #2941 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: GT3B Hack Question and Answer Thread
This is how I used to have it set up on v4.1 ch3 will swap between 4ws and crab ch3 trim will go between rear steer(left), 4ws(mix)(center) and front steer(right) sub menu EPOINT (4) to channel 4, 0%, NOC sub menu rev 3 4WS, NOL, 100%, NOR, NOO sub menu rev C 4WS, SWI, NOR, NPV, OFF Steering Front is plugged into Channel 1 Steering Rear is Plugged into Channel 4 _________________ |
07-11-2013, 12:19 AM | #2942 |
I joined the Band! Join Date: Jun 2013 Location: rohnert park
any way to get a discount if i send in my GT3b for a hacked controller?
07-11-2013, 12:34 AM | #2943 |
| Re: GT3B Hack Question and Answer Thread |
07-11-2013, 06:02 AM | #2944 | |
| Re: GT3B Hack Question and Answer Thread Quote:
If you want a hacked GT3B, I would just get a hack kit and do it yourself. That's providing OverKillRC would even do the swap. | |
07-11-2013, 01:49 PM | #2945 |
Just being lazy.
07-11-2013, 11:35 PM | #2946 |
| Re: GT3B Hack Question and Answer Thread Well atleast you are honest..... It really takes about a couple hours total to do all of the mod, after you have done a few. Prolly a day first time. Doubtful that Austin will even swap ya due to cannot be trading out for used and broken tx. He sells new ones that are hacked, not used ones.
07-12-2013, 08:20 PM | #2947 |
ok, i'll just order the hack, anyone running a novak m2 here?
07-13-2013, 06:51 AM | #2948 | |
PS, once you get it set, if you recalibrate the ESC you have to redo all the settings again. I don't recommend the M2 Dig as an ESC, but try it if you have it. | |
07-13-2013, 01:07 PM | #2949 |
hmm, that's what i have. hopefully i can get it to work good, saw a video of someone running it, seemed to work good. guess i'll have to find out.
07-14-2013, 12:52 AM | #2950 |
07-15-2013, 08:26 PM | #2951 |
Rock Stacker Join Date: Feb 2013 Location: United States
Just curious how I would go about setting the gt3b for controlling the 3 speed transmission in a Tamiya High-lift.
07-15-2013, 08:38 PM | #2952 |
07-16-2013, 03:56 AM | #2953 |
I Do Best thing I've Bought Lol Not Sure How To Setup dig.
07-16-2013, 05:17 AM | #2954 |
07-16-2013, 05:40 AM | #2955 |
I Have The Latest Firmware. That Is Exactly How It Works.
07-18-2013, 03:30 PM | #2956 |
Rock Stacker Join Date: Jan 2012 Location: uk
hay guys, I dare say this has been covered a few times, however I hacked my gt3c yesterday, and after a day of searching i am a little confused. I want to set up 4ws which I have got working some how, however I want to select front steer or rear steer or 4ws/crab, now I can set crab or steer by switching the direction of one of the servos. i am just a little confused how to set the steering up. I did rear the manual, but it went over my head a little lol |
07-18-2013, 10:24 PM | #2957 |
Newbie Join Date: Aug 2011 Location: conroe
Picked up the remote for the first time in months, and I've done it again. Messed up a setting I shouldn't have. Turned on crab walk, and now somehow pulling back on trigger turns rear wheels left, pushing on trigger turns them right AND engages reverse. Front wheels turn normally with steering wheel. Been to long and don't remember how to fix.
07-19-2013, 06:48 AM | #2958 | |
07-19-2013, 08:01 AM | #2959 |
This is how I did it when using v4.1 I now and just controlling rear steer independently for more control...... ch3 will swap between 4ws and crab ch3 trim will go between rear steer(left), 4ws(mix)(center) and front steer(right) sub menu EPOINT (4) to channel 4, 0%, NOC sub menu rev 3 4WS, NOL, 100%, NOR, NOO sub menu rev C 4WS, SWI, NOR, NPV, OFF Steering Front is plugged into Channel 1 Steering Rear is Plugged into Channel 4 |
07-19-2013, 08:32 AM | #2960 | |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
