![]() | #301 |
Rock Crawler Join Date: Oct 2007 Location: Grants Pass
Can we have a count down timer added in the next firmware? ![]() |
![]() | #302 |
Pebble Pounder Join Date: Aug 2009 Location: taiwan
Yes, I programmed the esc before flashed, recalibration. Guess I better Just swap the wires and make things simple! ![]() |
![]() | #303 |
| ![]() This just a personal preference thing but I like to have reverse throttle at 100%. That way you can rock it back and forth to right it when it flips. Also i had a small dead spot with my castles around neutral. I kicked the deadband down on them to 1 setting past stock and it really felt way better
![]() | #304 | |
| ![]() Quote:
Its on the table, just working on how to implement it with the radio's limited screen | |
![]() | #305 | |
| ![]() Quote:
I'll add those posts you mentioned to page 1 here shortly, if anyone wants to dig up my tech i'll add it as well. Edit: I'm going to be copying over posts from the pre-order thread, because i plan to delete it here soon, just so ya'll know why random post will be popping up | |
![]() | #306 |
| ![]() BIND procedure FOR 3CH RX With your radio turned off
![]() | #307 | |
| ![]() Quote:
By the way, besides the verified success message, is there a simple way that I can check with my GT3B to make sure I flashed to the latest firmware properly? Thanx! | |
![]() | #308 | |
| ![]() Quote:
Long press enter and the firmware version should show, with "F" beign displayed on the left. If F isn't displayed the rotate enter till it is | |
![]() | #309 |
![]() | #310 |
RCC Addict Join Date: Jan 2010 Location: Dallas
I just ran across this thread by accident in some ways but I am liking this big time. I do have a general questions about the GT3B and then the hack. I am probably going to purchase one of these so my son who is really young can run a mrc on it (well and me too when I go to comps), and also so he can run a 2wd slash. That being said one of the settings I wish I could get in a cheap radio is being able to set the steering percentages for each side seperately, meaning left and right. I can do this on my dx3r and also on my 4pl. Am I right in understanding that the stock GT3b will not do this, but that the firmware update will? Thanks. RickM |
![]() | #311 | |
| ![]() Quote:
![]() | #312 |
Quarry Creeper Join Date: Apr 2010 Location: Centurion, GP, RSA
Just saw the GT3B is available local. http://www.customrc.co.za/transmitte...y_sky_fs_gt3b_ I'm very temted here. ![]() |
![]() | #313 | |
| ![]() Quote:
Unless you prefer to buy locally, just figured i'd let you know. Also, for those who've looked before, i revamped my shipping calculator so now international orders can be made on the gt3b, EMS only though...i've also added Express mail for domestic shipment as well. | |
![]() | #314 |
So the demons are still haunting me that I pmed you on ![]() |
![]() | #315 |
Losikid- I am not exactly sure if I am concerning myself with Epa's or Expo's to be honest. I think this is my issue. I know I can set up my right and left steering separately on my 4pl using a percentage from something like 1-120% depending on if I want to dial up (turning tighter) or dial down (wider turning radius). I would prefer to be able to do this with the GT3B as well, and I am getting the feeling that with the stock setup it something like a 1-100% for BOTH right and left, not separate. I think I understand that with the hack allows for a setup to be separate for right and left. Does that sound right? |
![]() | #316 | |
| ![]() Quote:
Also on epa, i believe you can, but you have to adjust c3 so its on the side you want to adjust | |
![]() | #317 | |
| ![]() Quote:
And it's default setup in the new firmware is to allow 1-120% however it can be adjusted so 1-200% can be allowed. But anything past 120 may be very harmful to a servo. | |
![]() | #318 |
Next batch of hack kits i'll have some new high efficiency voltage regulators. It'll increase your pack time by nearly 50% Right now, with backlight off, the current drain is ~110ma with the new VR its going to be ~60ma Right now with backlight on, the current drain is ~130ma and the new VR will be ~75ma Testing was done at 11.4V, pricing will be $10-15 and will require 3 solder joints...if anyone would like to pre-order lmk. |
![]() | #319 | |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| ![]() Quote:
![]() good job on keeping up the upgrades ![]() | |
![]() | #320 | |
| ![]() Quote:
I'm also planning on bearing mods (to steering), el backlight, some switches (so you can put switches where you want them), and afew more things. BUT fw hack kits and vr mods are what finances this stuff....all mods will be available in pre-hacked gt3b's. I'm also working a standalone gt3b computer...so it will just be the guts in a box, and you plug in a controller to it. So any modded pistol grip controller, game controller, stick controller, etc. can be used. Just plug it in. This will probably be my next project after bearings. As the el backlight is going to be a costly investment. Right now i'm still trying to figure out power though, as the box i want to use, there isn't going to be much room for a battery...I'l probably just have to order the box in so i can see for my own eye's how much room there is...because schematics arn't doing it for me. | |
![]() LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 01:49 PM |
