Thread: GT3B Hack Question and Answer Thread
Old 10-31-2013, 10:58 PM   #3201
Default Re: GT3B Hack Question and Answer Thread
Took it on a hike today, no issues. Used the winch only once though.. Maybe some interference in my apt? I'll give the bec a go once it arrives and keep testing.
robertjpjr is offline   Reply With Quote
Old 11-04-2013, 02:09 PM   #3202
I wonder if someone can help me here? One of my gt3b rxs looses signal at like 30 feet. I saw the antenna wire had a few scrapes and splits in it so i figured i would try to change it. I tried to solder a new piece of wire on but that only made it worse. Is the antenna wire a specific type of wire? And is it supposed to be soldered in 2 spots on the board? I know its only $10 for a new one but i enjoy trying to fix things anyway
Sent from my iPhone using Tapatalk - now Free
Jcplante is offline   Reply With Quote
Old 11-04-2013, 06:25 PM   #3203
Got Worms?
It uses a special coax wire and solders in two places....its easier and cheaper just to get a new rx
losikid is offline   Reply With Quote
Old 11-04-2013, 08:39 PM   #3204
Yeah after i looked at it some more i saw how it was supposed to go. I guess theres not really any fixing it then
Old 11-04-2013, 09:46 PM   #3205
Sorry guys I looked and read through a lot of pages and not finding the info I think I'm looking for. Getting ready to hack my GTB3, doing it so I can use the 3rd channel for a winch. Not sure which firmware to use. After I have the right firmware any help or links and how to set this thing up would be much apprieciated...
step child is offline   Reply With Quote
Old 11-04-2013, 10:59 PM   #3206
Got Worms?
Use 0.6.1
http://www.overkillrc.com/GT3X-Firmw...NUAL-0.6.1.txt
http://www.overkillrc.com/GT3X-Firmw...lp%20cards.pdf
and the last page of this
http://www.overkillrc.com/GT3C/Insta...anual%20v0.pdf
Old 11-04-2013, 11:23 PM   #3207
Originally Posted by jaloos View Post
Let me know how it works out for ya.
John
Got my BEC set at 7.2 volts with my new Flysky FS-GR3F Receiver with no issues. Thanks for the BEC tip! Love that the receiver is rated for 8.4 volts!!
Old 11-04-2013, 11:28 PM   #3208
Got Worms?
I've been meaning to test out the new HV receiver...haven't had a chance yet (well actually, i keep forgetting since i use frsky receivers on my personal radio)
But, cool, glad you got it working and that the new rx does work with the higher voltage.
Old 11-05-2013, 11:06 PM   #3209
Thanks losikid for the info and links...
and thanks for not flaming a noobie
John
Old 11-05-2013, 11:22 PM   #3210
Got Worms?
There's a reason this thread has 3000+ posts
Old 11-06-2013, 11:05 AM   #3211
Originally Posted by losikid View Post
It's my personal radio
I'll offer them soon for both radios...still making adjustments.
Any updates on the Radio Skins?
lilpanther is offline   Reply With Quote
Old 11-06-2013, 06:12 PM   #3212
Got Worms?
I asked to change the templates alittle bit but haven't gotten any results on that yet...
Old 11-07-2013, 10:47 AM   #3213
SuperShafty.com
Originally Posted by mjderstine View Post
Hey guys. anyone ever have issues with their dial on the gt3b. Mine will jump around all over the place while spinning it. It is almost impossible to select a model or dial in sub trims and end points now. Very frustrating issue.
Is there a replacement and or a fix for this. Or is this just a broken radio?
just wondering if anyone has experienced this before. should i just trash this radio and hack my spare? just really don't want to spend hours re programming all my rigs from scratch...
i assume there is no way to transfer the model memories to my back up radio right?
mjderstine is offline   Reply With Quote
Old 11-07-2013, 02:11 PM   #3214
Just wondering if anyone has experienced this before. Should I just trash this radio and hack my spare? just really don't want to spend hours re programming all my rigs from scratch...
I assume there is no way to transfer the model memories to my back up radio right?
Never tried it, but I believe there is a "save function" using the hack kit. Thus you could save what is in one TX and move to another TX.
I would see if I could fix the original issue 1st though. Could be a dirty pot (cleaned out with contact cleaner) or replace the pot.
No, I have not had your issue. Sorry.
Charlie-III is offline   Reply With Quote
Old 11-07-2013, 03:25 PM   #3215
Got Worms?
Try cleaning it out with contact cleaner....
Otherwise its easier just to use a different radio...
Yes you can save the models and load them into a different radio...
I haven't written up how to do this though ...
Old 11-10-2013, 09:51 PM   #3216
I seem to be a lost cause here... I keep trying to figure this damn thing out.. seems tho i have dual mixing or something on in my radio? is there a way to turn it off.. if so How? 0.6.1 Firmware... next is.. i am totaly lost on how to programe this thing i got the basic down now i wanna go all out on my C3 rig.. Can someone help me decode the manual for the following
1.Front Steering
2.ESC
3.Rear-Steering
4. Front servo winch
5. Rear winch
Zeks05 is offline   Reply With Quote
Old 11-12-2013, 07:22 PM   #3217
I have 2 GT3Bs (actually my sons') and want to turn one into an 8 channel since I have a few receivers sitting around, but I can't figure out where to get a programmer. Is it possible to use an Arduino as a programmer? I flashed a 9X with one before I got my SP board, but haven't found anyone attempting that with the GT3B. I have all the connectors and wire needed for the mods to connect to the programmer so I tore into one and did it, now I just need the programmer itself. Losikid, any idea when you'll have any?
SFT2 is offline   Reply With Quote
Old 11-12-2013, 11:14 PM   #3218
Got Worms?
If you order now, they'll ship in afew days...
And no, you can't use your arduino programmer...this is a stm8s chip not an avr
Old 11-13-2013, 12:05 AM   #3219
Gotcha. Wonder why Flysky went with an Atmel in the 9X and not in the surface radios. Would have been much easier on the devs and us. I'm surprised they haven't put a USB port in so we can more easily get in there and mess around.
Old 11-13-2013, 02:25 AM   #3220
Got Worms?
I don't think flysky considers us in the design...take the FS-it4 for example...the main chip is flysky badged so i have no idea what it is
And, i bet its all about price..
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html
Posted By For Type Date
RoboSavvy Forum :: View topic - SAM-3 Servo teardown This thread Refback 03-05-2013 01:49 PM
