![]() | #3301 |
Its got nothing todo with 3dcart, that chore i'll tackle later on down the road...And, the way they have their servers setup i may have todo a cloned website, but i'll get it done all through html, css, etc. I'm just switching from justhost to ipage...at first I had some dns issues, i got those fixed, not i gotta figure out some other stuff to make files and stuff accessible through ipage. |
![]() | #3302 |
I joined the Band! Join Date: Jun 2013 Location: rohnert park
bought a new reciver, same that comes with the gt3b, i cannot get this thing to bind for the life of me, i feel like i have tried everything. any tips? i think my receiver is a dud, i was able to rebind my old receiver. the light blinks slow when i turn it on and try to bind, unlike when i bind my known good receiver which has a faster blinking red light in bind mode Last edited by ncampos976; 01-06-2014 at 08:35 PM. |
![]() | #3303 |
Rock Crawler Join Date: Aug 2011 Location: south shore Ma
I have had problems like this before with binding. Im not sure what made it work but i tried a few different things. I tried to power it up from a rx pack from a nitro instead of an esc. I tried unplugging everything but the esc. Different combinations of what i powered up first and how long i waited. I have 8 of these rxs and they all did bind eventually but it seems like some just want to give a hard time first for some reason.
![]() | #3304 |
Sometimes having the RX & TX antenna's touching when doing the bind works. As mentioned, some RX's are just a bit flakey compared to others. How are the batteries in the TX? |
![]() | #3305 |
Quarry Creeper Join Date: Jan 2012 Location: Bloomington
Can you set a fail safe on 6 or 8 ch receivers or is that just on the 3 ch?
![]() | #3306 |
RCC Addict Join Date: Oct 2008 Location: south caki laki again
took mine out today for its first comp, done extremely well after i got used to the switch set up, gonna work on something to move the front dig to steering wheel area.
![]() | #3307 |
![]() | #3308 |
Quarry Creeper Join Date: Jun 2010 Location: Carson City, NV
So I've got the gt3c. I have it hacked with 0.6.1 and I need help setting up the extra channels. I need a two position and three three position switches. The three positions are for a front and a rear winch setup and 4ws. how can I do this?
![]() | #3309 | |
Quarry Creeper Join Date: Mar 2012 Location: New Jersey, USA
| ![]() Quote:
Also a link to the manual. GT3B Hack Question and Answer Thread | |
![]() | #3310 | |
| ![]() Quote:
![]() | #3311 |
Quarry Creeper ![]() Join Date: Nov 2013 Location: Huntsville
And remember to back ALL THE WAY OUT OF THE MENUS after making adjustments. I successfully programed my 3-position switch on the first try but spent an hour figuring out why it wasn't working. Doh!
![]() | #3312 | |
Rock Crawler Join Date: Apr 2009 Location: NE Ohio
| ![]() Quote:
So I'm finally getting around to the point where I'm going to mess with my program settings on my gtb3. All I need is momentary switches for all of the additional channels, for a shift servo, light controller, winch, 2 firgelli actuators (basically same as winch), and eventually a screw drive system. Anyway my question is about the above programming, is this what I need and is it the same for all the additional channels 3-8 to set them up as momentary switches? I don't need mixing or anything else at this time. My only real concern would be the winch and actuators I need them setup to operate like the controller they come with operates. Push button -- out, Push button -- neutral or stop, Push button -- in Thanks for any input you can give, I'm trying to go through the programming sheet but I'm lost on some of it ( prob because my heads all fuzzy from this stupid cold) --Dan | |
![]() | #3313 |
Rock Crawler Join Date: Dec 2009 Location: Chicago
FlySky FS-3TB with updated version 0.6.1 firmware recipes for 4WS, 2-speed and winch. Activate 4WS mix 4 3 0 CR0 Map the 4WS mix to ST trim buttons 1 4WS BNL 100 RE0 OR0 Map CH 3 button to turn 4WS crab on/off C 4WS MO0 RE0 PV0 OFF Map D/R switch to control winch (channel 5) d CH5 BMO RE0 PV0 Map back to control 2-speed (channel 6) b CH6 MO0 RE0 PV0 OFF * Adjust the endpoints for CH6 as necessary |
![]() | #3314 |
Pebble Pounder Join Date: Sep 2013 Location: Portugal/Lisboa
Does anyone now if there is a video showing how to hack the GT3C, I have all thats needed but the instrutions are a bit confusing.
![]() | #3315 | |
Pebble Pounder Join Date: Aug 2012 Location: Australia
| ![]() Quote:
Flysky GT3B Hack PSX's Custom Firmware 0.61 How to hack? 8 channel 4-wheel steering Dual ESC Mixing - YouTube | |
![]() | #3316 | |
| ![]() Quote:
Thank you, just one more thing, I have the GT3C I think most of the programming is the same, but thats for a 8ch and I have a 6 channel, is the program fro that video diferente for the 6channel? | |
![]() | #3317 | |
| ![]() Quote:
You run how many channels you need. I have one rig running 4ch (6ch TX),another running 3. | |
![]() | #3318 |
![]() | #3319 |
![]() | #3320 |
Yes I tryed looking in google but didnt finf nothing for the GT3C, just for the GT3B and didnt now that its the same. Just one more thing, I have a Light controller that has 8 mods could it be possible to use a channel and set eache mod foward our backwords? |
![]() LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 01:49 PM |
