08-03-2011, 07:40 PM | #321 |
Rock Crawler Join Date: Oct 2007 Location: Grants Pass
| I tried them all. I even switched to a new fresh model, and switched ch2 and 3 to rev just like before. Now when I try to calibrate the escs the front one will arm and the rear wont. I will get a vid of some of the odd things i am encountering
08-03-2011, 07:43 PM | #322 |
| But it works fine on your other moa?
08-03-2011, 07:59 PM | #323 |
08-03-2011, 08:31 PM | #324 |
Pebble Pounder Join Date: Aug 2009 Location: taiwan
Not sure I have the same problem as highlandcrawler. Finished calibrated front esc on ch2 yesterday, today tried the rear esc on ch3 but fail, I can only completed calibrate esc on ch2, on ch3 only forward and backward calibrated but neutral failed(no matter front or rear esc) so the rear motor is not running. Please help. Thanx! |
08-03-2011, 08:38 PM | #325 | |
08-03-2011, 09:05 PM | #326 |
try 0.3.2 It may be a bug in 0.4.0, as i have done little testing...but as far as i know nothing changed mixing wise. |
08-03-2011, 09:39 PM | #327 |
Here are my current setting on the radio. The only thing i don't show is that ch2&3 are reversed http://youtu.be/YEEbPJjWPkQ These are all correct right |
08-03-2011, 09:44 PM | #328 | |
08-03-2011, 09:48 PM | #329 |
also you went into Long click epa and turned dig on, correct?
08-03-2011, 09:57 PM | #330 |
| To also clarify I have the truck running on a model already. It just seems like there is something wrong in the settings and that is why I am trying to calibrate to a fresh model. I can recalibrate the speedos in this model and all is ok. Its when I switch to a new model and try to calibrate the escs the rear one just wont finish arming. It goes to the end and never finds neutral. I will post a vid in a minute of me trying to arm to a new model
08-03-2011, 10:03 PM | #331 | |
kinda hard to calibrate if mixing isn't turned on to move ch 3 | |
08-03-2011, 10:05 PM | #332 |
Long click EPA scroll to d, enter scroll to 3, enter make sure it says 0, long click enter |
08-03-2011, 10:11 PM | #333 |
| In my working model it switched the way my f/r digs works but did not let me calibrate in the new model In my working model it is set up yes. I left it out of the vid as I figured it was a given lol. On the fresh model only thing I changes is ch2&3 to rev Guess what? You nailed my arming problem right there. They both calibrate perfect now. Cant belive I missed that. Now to see if the other demons from the previous ch are still there. Thanks a ton and I will report back later on how it works. |
08-03-2011, 10:18 PM | #334 | ||
yep kind of an important step. | ||
08-03-2011, 10:31 PM | #335 |
Newbie Join Date: Mar 2011 Location: Port Orchard
will the gt3b work with the M2 Dig 3S Dual Brush ESC? |
08-03-2011, 10:32 PM | #336 |
08-03-2011, 10:33 PM | #337 |
08-03-2011, 10:35 PM | #338 |
08-03-2011, 10:47 PM | #339 |
havent got the m2 yet was thinkin about it im just not that good with the whole electronics part of crawling
08-03-2011, 10:54 PM | #340 |
Dual ESC Mixing Template: (0.3.2 and 0.4.0 fw's) Ch3 trim-Momentary 3 postion dig D/R-Bias with 20% step rate
Plug front into CH2 Plug rear into CH3 Plug your battery in, and calibrate your esc's Last edited by losikid; 08-03-2011 at 11:43 PM. |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
