08-03-2011, 10:55 PM | #341 | |
Not much harder to wire in a crawler. and gives you alot more options | |
08-03-2011, 11:37 PM | #342 |
Rock Crawler Join Date: Oct 2007 Location: Grants Pass
So it looks like my biasing demons followed over to the fresh model just the same. This clip is just a very minor example of what is going on. When the truck is on the rocks with a load the strange things are far more drastic. Like when the biasing decides to catch up sometimes it will leap it comes on so hard. Sometimes the front or rear motor wont wanna come back until 3/4 throttle or so. This video is very bad as I just dont have enough hands to work with lol http://youtu.be/xVv570V5RtU |
08-03-2011, 11:41 PM | #343 | |
08-03-2011, 11:42 PM | #344 | |
I want to say your motors, or esc's are f'd up or you have a bad connection somewhere. have you tried 0.3.2? | |
08-03-2011, 11:45 PM | #345 | |
i fixed it | |
08-03-2011, 11:50 PM | #346 |
i'll flash 0.4.0 tomorrow to mine, see if it does it to me. But i think your problems are elsewhere. |
08-03-2011, 11:53 PM | #347 |
| Speedos are new in the mail yesterday direct from castle still with new stock labels. Motors are Holmes motors with 1 comp and a couple hrs practice. they have new brushes also. Im using bullets for motor connection and deans at the battery all have good joint and no cold joint either. I haven't tried the other firmware yet.
08-04-2011, 12:05 AM | #348 |
08-04-2011, 12:17 AM | #349 |
| Yes I installed them. I had a problem with the stock ones. I got ahold of Eddieo and he told me the best ones to get for my application. Com was cut fresh for its first time then broken in on 4v. They are not tight in the hood but they are correctly seated and move in and out freely. Where can I get the other firmware you suggested?
08-04-2011, 12:18 AM | #350 |
I just reflashed mine to 0.4.0 and copied your settings. I don't have these problems...i'm running hh br-xls (basically castle, i think) and rebadged broods |
08-04-2011, 12:19 AM | #351 | |
here's an archive of all the old fw's... http://www.overkillrc.com/apps/links/ | |
08-04-2011, 12:22 AM | #352 |
Turn off the mix, and see if ch 2 will work each esc without it only working part of the time I'm pretty confident you have problems else where... |
08-04-2011, 12:26 AM | #353 |
I will skip the software then if yours didn't do it. I will swap in a set of broods i have here and see if than makes a difference. The motors don't do anything odd or any of the electronics really until the biasing comes into the picture. I can drive around and dig just fine until I start mixing.
08-04-2011, 12:29 AM | #354 | |
08-04-2011, 12:31 AM | #355 |
08-04-2011, 12:34 AM | #356 |
08-04-2011, 12:34 AM | #357 |
08-04-2011, 12:37 AM | #358 | ||
08-04-2011, 12:37 AM | #359 | |
so what do you mean by you can drive around with no mixing? | |
08-04-2011, 12:38 AM | #360 |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
