![]() | #361 |
Rock Crawler Join Date: Oct 2007 Location: Grants Pass
And also thanks very much for taking the time to work on this with me. I really appreciate the support ![]() |
![]() | #362 |
![]() | #363 |
| ![]() I should say biasing I guess. As long as I don't hit the dr buttons above the digs it goes fine. Im gonna try different motors first and see. If thats the same I will hook it up to the 4pl off the other truck and see what it says with it. Then swap the castles for some fxrs and see I guess. I have a second gt3 here also I might even try that with its receiver?
![]() | #364 | |
| ![]() Quote:
If it does then there is a problem with the gt3b if it acts the same as the gt3b, then its the crawler. You have another GT3 or GT3B? | |
![]() | #365 | |
| ![]() Quote:
![]() | #366 | |
Pebble Pounder Join Date: Aug 2009 Location: taiwan
| ![]() Quote:
everything seems fine and very happy that I did it. Is there a way to modify the D/R and CH3 trim buttons, to make them more easy to control? Thanx! Last edited by kc092755; 08-04-2011 at 11:06 AM. | |
![]() | #367 | |
Quarry Creeper Join Date: Apr 2010 Location: Centurion, GP, RSA
| ![]() Quote:
Would rather get the firmware kit. Cheers | |
![]() | #368 | ||
MEOW ![]() Join Date: Jan 2006 Location: Corruptifornia
| ![]() Quote:
Here ya go! lol ![]() ![]() ![]() Quote:
![]() ![]() Last edited by Natedog; 08-04-2011 at 11:10 AM. | ||
![]() | #369 |
![]() | #370 |
| ![]() Yes it'll be separate, and it isn't related to the firmware at all so it'll work on un hacked and hacked models...
![]() | #371 | |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| ![]() Quote: ![]() ![]() | |
![]() | #372 |
![]() | #373 | |
| ![]() Quote:
Or do you hold it other way? | |
![]() | #374 |
Rock Stacker Join Date: Jul 2011 Location: Elk River, MN
I have been wanting to update the radio in my LCC because my current radio only has a 2 pos switch rendering me with out rear dig. But.....I am soooo confused about this radio, does it have a 3 pos switch for channel 3 stock or does it have to be modded?
![]() | #375 | |
| ![]() Quote:
So you have to reflash it with new firmware...to reflash it requires afew simple solder joints, and cut a spot in the plastic. With the new firmware you can map the 3 pos switches already on it to control Ch3 | |
![]() | #376 | |
| ![]() Quote:
![]() Second question then, when ordering a pre-hacked radio from you it comes with one receiver automatically? | |
![]() | #377 |
![]() | #378 |
Hey guys, the voltage regulator mod is now for pre-order http://www.overkillrc.com/products.h...roduct=5851481 it will require you to take a pair of snips, cut 3 wires, then making 3 solder joints. Thats it. |
![]() | #379 |
I wanna be Dave ![]() Join Date: Feb 2007 Location: South FL
is that the voltage regulator that will allow you to run 4 cells instead of 8?
![]() | #380 | |
| ![]() Quote:
Thanx! | |
![]() LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 01:49 PM |
