02-27-2015, 12:38 AM | #3881 |
| Re: GT3B Hack Question and Answer Thread
GT3C Update: I'm hoping to get all orders shipped out tomorrow. I'm going to try and get 10 more posted this weekend or sometime next week. I have another batch of 20 coming in from china as well. Hopefully they don't get held up in customs again |
03-01-2015, 12:10 PM | #3882 |
Newbie Join Date: Mar 2015 Location: Ohio
I've recently upgraded my GT3b's firmware and I have a timer question. I searched and found some info but I didn't see anything yet that answers my question. I did find how to assign a button to turn off a timer and reset it so that being said here is my question: I was wondering if there is a way to not only start the timer with the throttle but also pause it with the throttle position in neutral. This is useful to see how long a battery lasts when the vehicle is under load of the throttle. I have a similar function on my DEVO 10 and I can then use that data to set a count down timer set to a known battery life time. In this way when I'm controlling my boat and the timer counts down I can know when to bring it back before the battery cuts off. Also, where can I find the firmware setting for the throttle that turns on a timer? I hope I'm not asking someone to reinvent the wheel, If there is a thread on this can you point me to it. Thanks! |
03-01-2015, 01:13 PM | #3883 | |
| Re: GT3B Hack Question and Answer Thread Quote:
Code: Operating timers: ================= - select timer1 or timer2 main screen with rotate encoder - timer1 is identified by left arrow, timer2 by right arrow - lap count is written to 3char LCD place - timer value is writen to 7seg + 3char LCD place in format: 0000 - MMSS minutes, seconds 0000 % - SSHH seconds, hundredths (0.01 seconds) - press ENTER to set timer params, use it as usual menu: H set throttle trigger start OFF/ON timer will start after throttle forward applied A set alarm 0..255 in laps for lap counter in minutes for others P set timer type: OFF timer is off UP up timer TxS start/pause timer TxR stop + reset timer DWN down timer TxS start/pause timer TxR stop + reset timer and save rest time to lap times when alarmed at time 0, starts counting up with "V" symbol blinking LAP lap timer - 100 lap times are saved TxS record lap time, show it for 3s blinking and during this time presses are ignored to eliminate double click when timer not running, start timer when timer alarmed, stop timer and save lap time TxR stop timer LPC lap counter - till 255 laps TxS increment lap counter, minimum 3 seconds between presses are required to eliminate double click TxR zero lap counter - pres ENTER-long to show saved lap times (only for LAP and DWN timers): > It is possible to see lap number (indicated by 'L' at 7seg number) or time showed as other timer values. Press ENTER to switch between lap number and time value > use rotate encoder to switch between lap numbers or lap times > there are special lap number identificators also at 3char display: - Txx - total time, 'xx' is number of laps - Axx - average time, 'xx' is number of laps - RES - pres ENTER and lap times will be erased, it is also displayed when showing lap time Code: Functions assignable to keys: ============================= OFF - nothing CHn - switch channel "n" value from one end value to opposite end value. There is special handling for CH3 button. When using 3-position switch instead of CH3 button and momentary is selected for this button, then centre 3-pos value will also be detected and set to servo (use 1K resistor to GND to get middle state) CnR - reset value of channel "n" to centre 4WS - switch crab (CRB) no-crab (NOC) for 4 wheel steering DIG - switch DIG mix between -100 and 100 (more useable when using return to previous val key setting) DGR - reset DIG mix to centre MP1 - Multi-Position 1, switches position up (at END back to 1.) MR1 - Multi-Position 1 Reset, switches position to first one MP2 - Multi-Position 2, switches position up (at END back to 1.) MR2 - Multi-Position 2 Reset, switches position to first one MP3 - Multi-Position 3, switches position up (at END back to 1.) MR3 - Multi-Position 3 Reset, switches position to first one MP4 - Multi-Position 4, switches position up (at END back to 1.) MR4 - Multi-Position 4 Reset, switches position to first one T1S - start/pause timer1 T1R - stop + reset timer1 T2S - start/pause timer2 T2R - stop + reset timer2 BRK - switch on full brake, this overrides throttle position BLS - battery low shutup, stop beeping, predefined to END-long Code: - Key mapping specific for each model: > choose menu REV and press ENTER-long > menu REV will blink > choose trims (id: 1 2 3 d) or other keys (CH3: C, Back: b, End: E) or if trim is OFF, then also trim keys (id 1 2 3 d with left/right arrow) > press ENTER and modify first setting > press ENTER and modify next setting > .... ----- ----- steps of setting of keys (C b E 1< 1> 2< 2> 3< 3> d< d>): - sequence: function -> momentary -> reverse -> prev_val -> function_long -> reverse_long -> prev_val_long - function: selected function listed at the end of manual - MO momentary: only available for 2-state functions (channel, ...) 0 - switch, key press will switch something (channel value, ...) 1 - momentary, value change will be active only while key is pressed - RE reverse: only available for 2-state functions 0 - normal, no-press or default value is left endpoint 1 - reverse, no-press or default value is right endpoint - PV prev_val: only available for 2-state functions 0 - key release or OFF state sets value to left endpoint (noREV) 1 - key release or OFF state sets value to value active before key press or ON state - function_long: function applied when long press of key happens, choose from the same list as function, identified by "V" symbol - reverse_long: same as "reverse" + "V" symbol - prev_val_long: same as "prev_val" + "V" symbol | |
03-01-2015, 02:29 PM | #3884 |
OK, thanks for the quick reply. It was worth a shot. Maybe it's a possible future firmware upgrade. I suppose if it isn't a popular request, it may not warrant time to be spent on it. I do appreciate all the new features I have now! Inactive alarm, custom voltage level alarm especially helpful for LiPo upgrade to mention a few favorites. Thanks! |
03-01-2015, 03:29 PM | #3885 |
Can anyone explain how the model memory works as it pertains to uploading new firmware? I saw something about the firmware versions x.x.x and what is effected depending on the version level. So I was wondering if at anytime the models stored in memory will stay in memory when a new firmware version is loaded. I understand going from stock to 0.6.1 would wipe out the models stored in memory. Is there a way to back these up? Are the models in memory not deleted if you go from 0.6.1 to lets say 0.6.2? Does it depend on where the models are saved? i.e. location 0-8 in EEPROM and the rest in FLASH, is the EEPROM overwritten every time you upgrade? Is the FLASH safe from being overwritten when upgrading? In short is there any mode or procedure to be able to keep the models in memory or a way to back them up and load them after an upgrade? Thanks for your time. |
03-01-2015, 05:40 PM | #3886 | |
https://github.com/semerad/gt3b/blob...VersionNumbers | |
03-03-2015, 07:02 PM | #3887 |
I think I understand. As long as I am 0.6.x I will not lose my models if I upgrade from 0.6.1 to 0.6.2. IF I go to 0.7.x there's no guarantee at this time. Is this the correct thinking? Is EEPROM vs FLASH storage locations no advantage when it comes to version upgrades and whether or not the modules are unaffected. Thanks again! |
03-03-2015, 10:11 PM | #3888 |
Yes, you are correct
03-05-2015, 03:36 PM | #3889 |
Newbie Join Date: Mar 2015 Location: yelm
hey everyone new to the Gt3b controllers. I went to do the lipo mod and then i found out thati need to update the firmware because i have the low battery alarm going off because im using a 2s battery. now my question is there someone they can be sent to do the upgrade? thanks
03-05-2015, 03:46 PM | #3890 | |
Newbie Join Date: Dec 2013 Location: cleveland
03-05-2015, 04:37 PM | #3891 |
Rock Crawler Join Date: Jun 2013 Location: Knox, IN
losikid. Any idea when you are going to get more of the GT3C 4 pin adapters in stock? Can you pm me when they come in?
03-06-2015, 09:37 AM | #3892 | |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
As for sending to get hacked..... I think all should be hacked....... Austin will not do pre owned radios due to issues he has had in the past. I was willing to do them but ended up with issues myself with non working radios, broken radios and radios that needed more mods such as the voltage regulator and bearing mod but people didn.t want to do but then complained about not bing it done later just to sell radio and complain more about it. So I stopped trying to help out. I have a couple here...... My personal radio and couple back ups fully modded, may sell one day but really all the mods are worth doing and really not that hard with basic hobby tools. Ie: good quality soldering station with small tip and body reamer. | |
03-07-2015, 06:07 PM | #3893 |
Hey guys, I posted GT3C's to my site yesterday. They're going fast. I should have more in about a week. |
03-07-2015, 11:39 PM | #3894 |
Newbie Join Date: Nov 2007 Location: Surprise
plugged in my programmer (GT3C) started beeping on kept beeping (low power error). Opened what I thought was right firmware . soon I as ran the program the beeping stopped. Waited till it was all done (verified) and now she is dead to the world. even plugin the programmer back in it does not give it power like it did before. Did I kill her?
03-08-2015, 01:25 AM | #3895 |
What firmware file did you open?
03-08-2015, 10:29 AM | #3896 |
I did not see anything that was close to 6.1 so i did what and thick headed man would do an took a guess. The only thing i saw that was similar to anything i have seen was: swim.s19. |
03-08-2015, 12:09 PM | #3897 |
austin, l messed up trying to program my ch3.trim for dig servo. somehow i got the servo working using the 'end point adjuster' screen and the scroll wheel. how can i change it back to ch3 trim button? it was working on the ch3 trim like i wanted it to, then i changed it somehow. i'm using 0.6.1. my settings (current): long press EPA 4 off d off p 1 0 p 2na p 3na p 4na b off 8 off It was working on: long press REV 3 ch3 3 BNL 3 30v 3 RE0 3 OR0 thanks, tom |
03-08-2015, 02:59 PM | #3898 |
Got it. Reset the TX back to default settings. All is good for now...
03-08-2015, 05:12 PM | #3899 | |
Newbie Join Date: Mar 2015 Location: EP
so i tried following this to set up four wheel steer, and i like the St trim to select modes, however i have a GT3C and i don't get the same prompts as mentioned in the original set up. This is what i get and how i got it to work as described Activate 4WS mix Long click EPA--ok 4--ok 3--ok 0--ok NOC-- Options CR0 or CR1, and it looks like this chooses if the servos oppose or follow each other Long enter--OK Map the 4WS mix to ST trim Buttons Long Click REV--OK 1--ok 4WS--ok NOL-- BNL 100--ok NOR-- RE0 NOO-- OR0 back Map CH 3 Button to turn crab on/off Long click REV--ok C--ok 4WS--ok SWI--MO0 NOR--RE0 NPV--PV0 OFF--ok back now i have a question. i have the six channel FS receiver. my front servo on ch. 1, rear servo on ch.3 and want to add a dig servo on ch.4. i my TX or RX dont seem to recognize ch. 1, 2, or 3. how do i get them to be recognized? and How do set up ch.4, the dig, to activate with ch.3 trim button when pushed to the left and only engaged as long as i'm holding the button to the left and disengage when returned to normal? thanks | |
03-08-2015, 07:31 PM | #3900 |
Got it had to find and save the file first. Now I think i got it. I seem to have around 60 models now.
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
