![]() | #4101 | |
Newbie Join Date: Aug 2015 Location: Dryden
| ![]() Quote:
Also, The CR3P is the same as the GT3B, Look at the receivers, They are the same except that Absima claims theirs are waterproof (Bonus). The layout is like the iT4 but it has the GT3B guts, Plus it only takes four double "A" batteries as opposed to the eight that the GT3B takes. Absima has an iT4 as well, Theirs is called the CR4T and it has a dedicated crawler firmware that can be downloaded from their website. Plus the CR4T doesn't have that annoying engine rev sound when turned on or that stupid pokey antenna sticking up, The CR4T can also be changed to accommodate left handed users too, Seems more like a grown up transmitter and less like a toy (My 2 cents). Last edited by Gadget-Geek; 08-28-2015 at 12:16 PM. | |
![]() | #4102 | |
Rock Crawler Join Date: Feb 2015 Location: Melbourne
| ![]() Quote:
![]() | #4103 | |
| ![]() Quote:
Here is the right way to register MSCOMM32.OCX in Windows 7 64 Bit. First download MSCOMM32.OCX from the internet and copy it to your Windows SysWOW64 folder then click on "Start" at the bottom of the window that pops up it will say "search files and folders", Type cmd and a window will appear that has an icon with cmd next to it, Right click on it and run as administrator. A user account control window will open then click "Yes" The command prompt box should open and say Administrator on the top left. The cmd window should have c:\Windows\system32> with a blinking cursor, If it has your user name after Windows that's O.K. too. Now type "regsvr32 c:\windows\syswow64\MSCOMM32.OCX" without the quotations and hit enter, It should register successful, Restart your computer and you should be good to go. The reason this happens is that MSCOMM32.OCX is a VB6 runtime and Windows 7 no longer supports VB6 so you have to manually tell it where to look when running programs that were written in VB6. Those who aren't having issues probably installed a program that installed the runtime automatically. I hope this helps!. I haven't tried it in Win8 yet and with the different versions and updates, Getting to the user rights varies to much to be of much help to anyone, Therefore I would just use the patch and if that doesn't work, Google may be your last resort. | |
![]() | #4104 | |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| ![]() Quote:
I'm sure austin will chime in soon once he is done doing his deed..... But really? You came here on zero posts claiming this should work even tho you have not done it? Lol. Silly. And just fyi. The rx with the gt3b are waterproof as proven by users. And actually Absima claims they are water resistant not water proof. As for the rest, before you claim that x y and z are the same flysky board...... buy one. Take apart...... hack then come back and say it's so. And with the other board aren't you just restating what truebrit posted up a few posts down about the v2 board? That has yet to be confirmed if in so has been actually used to hack said radio? With a whooping savings of 5 dollars and couple cables? Same dog and pony show putting the carriage in front of the horse Last edited by JokersWild; 08-31-2015 at 06:41 PM. | |
![]() | #4105 |
Well I bought one of the V2 flash units in the hope that it workd. Arrived today. 5 days from Hong Kong. If it doesn't work then I'm only out $5.
![]() | #4106 | |
| ![]() Quote:
Not really the point since like I already said. The v2 has already been posted in another thread with no conformation if it works or not......... and on top of it the claims other stuff will work when it hasn't been done, so theories are just that and belong in their own thread not the one people will be going to for technical support on the gt3b/c where it could be taken as fact when it has yet to be put to that. | |
![]() | #4107 |
I agree with you. Should never have been posted without testing first. I bought one anyway as it was only $5.00. However at the time noone had replied to my questions about whether it had been tested yet.
![]() | #4108 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
Has anyone flashed the GT3B with windows 10 x64 bit? The last firmware I flashed was the one before the current. I haven't used my RCs or PC in quite a while and just updated to Win10 X64 and didn't think to update the GT3B to the newest firmware while i was on windows 7. I honestly don't even remember how I did it in the first place its been so long. I think I used an XP virtual environment? |
![]() | #4109 |
Quarry Creeper Join Date: May 2005 Location: edmonton
Are you still making these?
![]() | #4110 |
![]() | #4111 |
Pebble Pounder Join Date: Sep 2013 Location: Portugal/Lisboa
Has anyone had issues with the Flysky GT3 C after been hacked? Since I hacked it 2 years ago, the GT3 C is very sensitive on the adjustment wheel scroll button, for exemple, when trying to set Trim with the wheel scrool button, it goes from 50 back to zero, our from 90 to 25 our ather number, has anyone had this problem? Last edited by PSH72; 09-11-2015 at 12:47 AM. |
![]() | #4112 |
Rock Stacker Join Date: Aug 2014 Location: Pa
I have the same issue as above. I clicked this thread cause I was thinking about asking the same thing. sent from some loaction dat has da interwebs |
![]() | #4113 | |
| ![]() Quote:
![]() Plus, I'd have to write new instructions if I was to change programmers. I don't like making documentation... And the programmer isnt the expensive part of my kit. My markup is. ![]() | |
![]() | #4114 | |
| ![]() Quote:
Can you tell me if there is anyway I can fix this issue? | |
![]() | #4115 |
![]() | #4116 |
![]() | #4117 | |
| ![]() Quote:
I think that I solved my problem, since the wheel scroll dindnīt get crazy today, afther I calibrated the butoms. TragOul try and calibrate the buttoms and see if you can fix the issue of the wheel botton This is the issue I was talking about https://www.youtube.com/watch?v=QeNY...ature=youtu.be Last edited by PSH72; 09-13-2015 at 02:39 PM. | |
![]() | #4118 |
What method did you use to calibrate to buttons? sent from some loaction dat has da interwebs |
![]() | #4119 | |
| ![]() Quote:
Let me now if you got it right. Had no more problem of the scroll wheel since I did the buttons calibration. | |
![]() | #4120 | |
| ![]() Quote:
sent from some loaction dat has da interwebs | |
![]() LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
