08-08-2011, 06:40 PM | #421 |
Pebble Pounder Join Date: Aug 2009 Location: taiwan
08-08-2011, 10:26 PM | #422 |
Who'd be interested in programming cards? To go in your wallet or rc box. So it'll have afew tutorials, 3 pos switch, Multi postion switch, dual esc, 4ws, and then a shortcut quick card, so you can look and see what the abbrevs on the radio mean. Also, paper biz card? nearly free Thin plastic card? Cheap thick plastic card (like a CC)? abit pricy On another note, i plan on finishing up key mapping menu and writing tutorials this week....probably get to work on the rest of the manual. Still waiting on afew more hack kit orders to get some VR's in. |
08-08-2011, 10:30 PM | #423 | |
here is the snippet you'd be using, this ALOT simpler than key mapping Code: Global setup menu: ================== - enter it by ENTER-long - now menu items MODEL and NAME will start blinking - select requested item by ROTATE and press ENTER - use ROTATE to change value and press ENTER to end value changing - press BACK-long or ENTER-long to end global setup menu, values will be saved to EEPROM - selected menu items are indicated by following symbols: F firmware version (this of course cannot be changed :-) L backlight time 5s,10s...10m...MAX A inactivity alarm OFF,1m...10m LOW POWER! battery low voltage 7.5...10.5V E.POINT maximum allowed endpoint value 100...150% DANGER - values greater than 120% can damage your servo or will not be possible to transmit to receiver because of 2.4GHz HF module limitation This danger zone will be indicated with a flashing "d" symbol for values greater than 120% 1 dead zone for steering 0...50 2 dead zone for throttle 0...50 b key beep OFF/ON d long press key delay 100...1000 miliseconds r + ALL global reset - change to YES to set global configuration and all models to default values r + MOD all models reset - change to YES to set all models to default values | |
08-09-2011, 04:03 AM | #424 |
Got it, thanx!
08-09-2011, 04:55 AM | #425 | |
Newbie Join Date: Aug 2011 Location: thailand
because i am still dont really understand after read the manual. it's because my english not very good. i already translate it with google translate but steel confuse. | |
08-10-2011, 12:24 PM | #426 |
RCC Addict Join Date: Jan 2010 Location: Dallas
I just ordered the hack from Losi kid and am awaiting the radio from Hobbypartz. I have been looking at a lot of this and to be honest I think I am over thinking this some but why not right! I have a few questions as I get ready to go. 1 There appears to be a computer card in the $25 hack kit that is one the way to me. What is that for? 2. I noticed it looks like this is a three step process to get up and running. 1.is get the pins installed. No brainer. 2. is to plug it into the computer and flash it. Also looks easy. 3. It appears that you have to reprogram all your calibrations on the radio? Is this right? I am still hoping I can use this radio with the flash to program the amount of throw at right and left steering with right and left independant of each other. I am also wanting to be able to program throttle amount for a 5 year old with a slash!! I am super excited about this so thanks Losi kid. RickM |
08-10-2011, 12:28 PM | #427 | |
your steps seem right yes epa is independent, and its available for all channels. | |
08-10-2011, 12:39 PM | #428 | |
Rock Crawler Join Date: Oct 2007 Location: Grants Pass
EDIT: Hes a fast typer also | |
08-10-2011, 01:22 PM | #429 |
Tuning down the steering speed might help me with my newish 4wd slash! If this radio flash etc is as cool as the wantasummit 3pos switch and the was duel esc thingy, than count me as a fan already. I am not the greatest with electronic stuff as the details are my demons but I know I will eventually get it right and to be honest right now I am only worried about this as a 2 channel radio for an MRC and a slash. I might be ditching my 4pl if this is as good as it sounds though.
08-10-2011, 02:15 PM | #430 | |
And it is abit confusing at first how to program it, but its much easier once you understand how. | |
08-11-2011, 08:02 AM | #431 |
Quarry Creeper Join Date: Jan 2010 Location: Clover
Hi All, just to say that I have received the gt3b hacked by losikid yesterday, he does the job and the shipping very quickly. Once received I went to the post about how to set up the dual esc, 5 minutes later my berg was running ...dig and prop. dig are great ! Thank you very much Losikid, you've done a great work |
08-11-2011, 09:04 AM | #432 |
08-11-2011, 10:20 AM | #433 |
| Ok this is off the top of my head DIG to Ch3 trim (rx CH 3) 4WS to D/R switch (rx CH4) Winch to ST trim (rx CH5) Crab to ch3 Button Scroll to EPA Press and hold enter scroll to d press enter scroll to 3 press enter scroll to 0, press enter scroll to 4 press enter scroll to 4 press enter scroll to 0 press enter scroll to NOC press enter press and hold enter Scroll to REV press and hold enter scroll to 3 press enter scroll to DIG press enter scroll to RES press enter scroll to 100 press enter scroll to NOR press enter scroll to NOO press enter scroll to d press enter scroll to 4ws press enter scroll to RES press enter scroll to 100 press enter scroll to NOR press enter scroll to NOO press enter scroll to 1 press enter scroll to CH5 press enter scroll to RES press enter scroll to 100 press enter scroll to NOR press enter scroll to NOO press enter scroll to C press enter scroll to 4ws press enter scroll to SWI press enter scroll to NOR press enter scroll to NPV press enter press and hold enter press back |
08-11-2011, 11:44 AM | #434 |
So i woke up this morning and my computer had restarted...didn't think much about it Well i just went to go convert the finished key mapping manual over to a pdf and let ya'll take a look. But i lost it all, I had the buttons menu done and had abunch of templates/tutorials written So it may be awhile before i write it all again, |
08-11-2011, 12:05 PM | #435 |
I do have good news though....i have Voltage Regulators ordered, so they should start shipping next week...there will be 9 in stock after pre-orders have been sent out. My next project is adding a bearing to the st wheel to make it buttery smooth. . After that it'll probably be adding/moving switches. |
08-11-2011, 07:52 PM | #436 | |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
08-11-2011, 08:09 PM | #437 |
08-11-2011, 10:03 PM | #438 |
Well I mentioned I am not great with electrical stuff but this might sum it all up. I just got the stock GT3B in today and am waiting on the flash kit. I decided to try and go ahead and hook up the radio to my kids mrc. Well in doing so I am having a hard time getting my sidewinder micro esc to arm and communicate with the RX. I have bound it and my servo is working. It is getting its power off the battery anyway. I got my esc to start to chime and then it immediately starts flashing red. I tried to fire it up with my throttle in full gas mode but it keeps doing the same thing. I tried to trouble shoot it with Castle and they did not say much in the trouble shooting stuff. I double checked to make sure I am plugging everything in right and from what I can tell I do. Any ideas?
08-11-2011, 10:05 PM | #439 | |
08-11-2011, 10:10 PM | #440 |
I think I tried that once but I will try it again. It is almost like it is immediately kicking into a default mode before it has a chance to even try to go into settings or arm.
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
