01-01-2018, 12:06 AM | #4701 |
Quarry Creeper Join Date: Dec 2015 Location: Sutter
| Re: GT3B Hack Question and Answer Thread
I’d like to use the Ch3 button as a 2po switch to toggle between rock racing and crawler mode on my mamba x but can’t seem to get it correct. What should my settings look like. Sent from my iPad using Tapatalk |
01-02-2018, 01:31 PM | #4702 |
Pebble Pounder Join Date: Nov 2014 Location: Camby
I need to do this to mine. And also do what the guy above me asked about
01-26-2018, 08:03 PM | #4703 |
RCC Addict Join Date: Mar 2010 Location: RC Addict Garage
Recent tried to hack a new GT3b using the hack kit I have always used and I get "Device is protected" I have never seen this before, and it's always worked. Can anyone confirm is these are now somehow being protected from Flysky?
01-27-2018, 05:38 PM | #4704 |
Rock Stacker Join Date: Mar 2016 Location: Saskatchewan
I think i have heard that before. Not sure what that means...bad news if they did lock it. Can't imagine that would help there sales
01-28-2018, 12:53 AM | #4705 | |
Rock Crawler Join Date: May 2016 Location: SoWIs
| Re: GT3B Hack Question and Answer Thread Quote:
I've read your "ROP" or read out protection might be set ON. Under the window with all the HEX chars click on the OPTION BYTE tab. At the top is ROP, set to Read Out Protection OFF and try uploading firmware to the GT3B. If you fix this PLEASE report back, it will help others. | |
01-28-2018, 05:24 AM | #4706 | |
I can read and write to a gt3c I have here but these 2 gt3b will not work. They are brand new. This is first time with this issue and I've hacked literally dozens of them without issue. Tried a couple different computers too just in case it was a Windows 10 issue. | |
01-28-2018, 01:13 PM | #4707 | |
RCC Addict Join Date: Jun 2016 Location: Germany
I had the issue that i have to Connect all 4 lines and my Radio has to be powered on. That worked for me. Send by my Pixel 2 XL with Tapatalk | |
02-28-2018, 01:46 PM | #4708 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
I was trying to hack my radio today and am having some problems. I get to the point of plugging the radio in to the computer via USB port. Then I go to project page in ST visual programmer. I have downloaded the firmware file (gt3b-0.6.1.s19) but when I try to open it, I get error "not in Intel Hex format". I am not sure what that means or how to work around the error. Any suggestions would be appreciated. |
03-02-2018, 09:27 PM | #4709 | |
03-02-2018, 09:57 PM | #4710 |
| Re: GT3B Hack Question and Answer Thread |
03-03-2018, 01:52 PM | #4711 |
Newbie Join Date: Mar 2018 Location: Bronx
Going to be hacking a GT3B soon. Can I run 4 3.7v 18650 batteries? I know that puts me at 14.8v. Will this be too much voltage for the radio? Would it be better to add a regulator? Can I just run 3 of these batteries for the 11.1v? Thanks, Artechroach Last edited by artechroach; 03-03-2018 at 01:57 PM. |
03-03-2018, 07:18 PM | #4712 |
IIRC the regulator was spec'd for 18V (20v absolute max). It would be smarter to run them 2S2P and adjust the voltage alarm. The linear regulator gets more inefficient the higher the input voltage is above 6.5 volts, so 2S2P would last longer. Or you could replace the reg with a switch-mode regulator set to 5V get 2-3x the battery life with 4S.
03-03-2018, 07:22 PM | #4713 | |
So I should run it as a 7 4v setup parallel? I know that it normally takes 12v and just want to make sure that less voltage will be ok. Thanks for your response. | |
03-03-2018, 10:15 PM | #4714 |
| Re: GT3B Hack Question and Answer Thread I think 18650's are too big.....
03-03-2018, 10:36 PM | #4715 |
03-03-2018, 10:37 PM | #4716 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
I'd say they are Sent from my SM-N900T using Tapatalk |
03-03-2018, 10:39 PM | #4717 |
03-04-2018, 07:31 AM | #4718 |
I put 3 18650's in the bottom of my GT3B...had to customize a holder and it wasn't the best but it works!
03-04-2018, 10:46 AM | #4719 |
Sorry for all the questions. I see that the fs-r98b receiver is compatible "all channels with hack" I can bind the receiver and gt3b, but channel 1-3 don't respond. Should they work pre hack or is it only after the hack that will get those three working as well. Just want to make sure that my receivers work. Thanks! |
03-04-2018, 10:58 AM | #4720 | |
Also, are you trying to bind a 8 channel rx to the stock transmitter? | |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
