03-04-2018, 11:16 AM | #4721 | |
Newbie Join Date: Mar 2018 Location: Bronx
| Re: GT3B Hack Question and Answer Thread Quote:
https://rc.305.cz/storage/FlySky_Tx_...lity_table.pdf | |
03-04-2018, 11:25 AM | #4722 | |
As a side note, I have never tried to bind a 6 or 8ch rx to the stock firmware. I would suspect that it should work but I can't say for sure. It is odd the table identifies the GT3B with the hacked firmware note but not the GT3C. So maybe the GT3B does something weird? I unfortunately don't have a stock GT3B handy to test. | |
03-04-2018, 11:27 AM | #4723 | |
No worries. I will report back once I have done the hack about whether or not they work. The chart does identify both the b and c with the hacked note though, the C is right below the B | |
03-05-2018, 08:40 AM | #4724 |
Rock Crawler Join Date: May 2016 Location: SoWIs
I just checked my R9B (updated R8B), ch1/2 work with my unhacked GT3C and hacked GT3B. I can't get ch3 to work, but I don't have time to mess with it nor check 4+. All channels worked with my i6X when tested. Also Losi look at the table again, I think you are seeing the T2A line below as the GT3C line. |
03-10-2018, 09:26 PM | #4725 |
Has anyone had an issue where the ST program would not read the controller? Getting an error message saying that it cannot connect.
03-15-2018, 05:35 AM | #4726 | |
Rock Crawler Join Date: Feb 2015 Location: Melbourne
Sent from my SM-G930F using Tapatalk | |
03-15-2018, 09:31 AM | #4727 |
RCC Addict Join Date: Mar 2010 Location: RC Addict Garage
| Re: GT3B Hack Question and Answer Thread |
03-15-2018, 10:13 AM | #4728 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
03-15-2018, 10:52 AM | #4729 |
03-15-2018, 07:35 PM | #4730 |
Newbie Join Date: Mar 2018 Location: Terrebonne
Don't know if this might help http://translate.googleusercontent.c...Hauh_Ud1rjsgaw Sent from my LG-H915 using Tapatalk |
03-18-2018, 04:59 AM | #4731 | ||
Sent from my SM-G930F using Tapatalk | ||
03-18-2018, 05:10 AM | #4732 |
03-18-2018, 05:11 AM | #4733 |
03-23-2018, 09:04 AM | #4734 |
Newbie Join Date: Jan 2018 Location: The Netherlands
I had the same issue. The google translated link above did fix it for me, but not right away. For noobs (as I am) at this ST Link stuff, it's not all that obvious.. On the option byte tab the read protection was already off so at first I concluded that this setting was already ok but it still didn't work. A couple of desperate hours later I finally hit the 'program to current tab' anyways and suddenly the error was gone and I flashed the FW in a couple of seconds. It took me a couple of hours to discover this, so maybe this is your solution as well? TLDR Seemingly the actual setting in the tx can be ON, while option byte tab shows OFF. You simply have to program it anyways like the screenshot below shows: |
04-09-2018, 09:30 AM | #4735 |
Newbie Join Date: Sep 2016 Location: UK
First post from me, hopefully it may help someone. I just bought a GT3B with the intention of sticking PSX firmware on it, and had read the more recent "Device is protected" posts in this thread during my research. Figured I would risk buying one despite the reports of the "Device is protected" error ... I needed another transmitter anyway. Received the transmitter yesterday and today my ST-Link programmer dropped on the mat. I got everything set up and got the dreaded "Device is protected" message, seemingly no matter what I did. Started beginning to wonder if the latest STVP software and Win 10 was to blame. Went over and over through the methods highlighted by Bjorn above and found the same fix on a Youtube comment, "Make sure that the Read Out Protection (ROP) byte is set to off. Open STVP, go to the OPTION BYTE tab, set ROP to off and write out (Ctrl + P). Then, go to the PROGRAM MEMORY tab again and you should be able to write your hex file." Then I quite by chance discovered that in STVP 3.4.1 Ctrl-P does not seem to function on the 'Option Byte' tab. It only wrote (and updated the ROP) when I hit the Program current tab icon. So maybe like me some people are happily hitting ctrl-P like the few available fixes indicate, but never think to try clicking the icon/button instead?? Anyway, hopefully this might help someone. Off to read up all I can on configuring my GT3B now. 4WS is first on the agenda. |
04-09-2018, 09:46 AM | #4736 | |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
Ernie | |
04-14-2018, 06:47 AM | #4737 |
I also followed the above post for my self last night I just wanted to add that I had to use the 4 pins 5v swim gnd and reset for it to work. Also if anyone is still able to read and save their original software can you please send me a copy. I wasn't able to save mine as the device was protected. Thanks Sent from my LG-H915 using Tapatalk |
04-14-2018, 09:28 AM | #4738 | |
Rock Crawler Join Date: Feb 2012 Location: Michigan
04-17-2018, 11:58 AM | #4739 |
Newbie Join Date: Feb 2017 Location: On the road..
Is bangood the place to get the hack kits? I'm really thinking about doing this as I consider myself able to solder most things poorly!
04-17-2018, 12:02 PM | #4740 |
It's honestly not that hard all you really need is a 4 pin header because once you program it you forget it there hasn't been a Software update since 2011 I think Sent from my LG-H915 using Tapatalk |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
